Full Version: USB LCD - Few Options - Which can be used
Hello,
I have gone thru numerous threads and post for adding/plugging a LCD panel to KODI HTPC to display the media information,
My current HTPC is
Dell Studio Hybrid 140G
Intel C2D T9600
4 GB RAM
256 Gb SSD,
BroadCom CrystalHD MiniPCIE decoder.
Windows 7 32-Bit Professional
Kodi 16.1 Jarvis.
I am not an uber geek or DIY techie, I just have moderate info, knowledge and limited time available at my hand to tinker with the stuff to the extent possible.
I have come across the following options which are basically USB LCD panels.
http://www.goverlay.com/content/lcdsysinfo/
http://www.lcdmodkit.com/lcd/U204GMB-B1.html
Can some guru go thru the technical details and inform can they work with Kodi based on the currently available connection approaches via LCDSmartie or via iMON interfaces.
Would appreciate the guidance, so I can place the order to buy either of them in a limited time
Appreciate your responses.
