Full Version: Missing Install From Repository Option FIXED
Recently installed Kodi 17. I am unable to add any add-ons as I don't have the Install From Repository option. All I have is My Add Ons, Install from Zip File, and Search. I know to click addons & then the box icon top left of the screen. Install From Repository isn't an option. My date and time are set correctly. I'm stuck without the Install From Repository option. I've tried uninstalling and reinstalling. (Source files have been added so that isn't the issue. The option simply isn't there from the get go.)
Without it there I am finding I am unable to use Kodi.
Any suggestions?
I am using a Mac v10.11.6.
From the log: 11:12:58.196 T:140735284998144 ERROR: SQL: [Addons27.db] The database disk image is malformed
Query: CREATE TABLE installed (id INTEGER PRIMARY KEY, addonID TEXT UNIQUE, enabled BOOLEAN, installDate TEXT, lastUpdated TEXT, lastUsed TEXT)
11:12:58.219 T:140735284998144 ERROR: Exception updating database Addons27 from version 20 to 27
11:12:58.219 T:140735284998144 ERROR: Error updating database Addons27 from version 20 to 27
11:12:58.234 T:140735284998144 NOTICE: Old database found - updating from version 20 to 27
11:12:58.642 T:140735284998144 NOTICE: Attempting to update the database Addons27 from version 20 to 27
11:12:58.643 T:140735284998144 ERROR: SQL: [Addons27.db] The database disk image is malformed
11:12:58.643 T:140735284998144 ERROR: Exception updating database Addons27 from version 20 to 27
11:12:58.643 T:140735284998144 ERROR: Error updating database Addons27 from version 20 to 27
11:13:01.536 T:140735284998144 ERROR: SQL: [Addons27.db] SQL error or missing database
Query: SELECT addonID FROM installed
11:13:01.536 T:140735284998144 ERROR: SyncInstalled failed
Query: SELECT addonID FROM installed WHERE enabled=0
11:13:01.536 T:140735284998144 ERROR: GetDisabled failed
11:13:01.538 T:140735284998144 ERROR: SQL: [Addons27.db] SQL error or missing database
Query: SELECT * FROM installed
11:13:01.538 T:140735284998144 ERROR: GetInstalled failed
You are my hero!!!!! It worked.
