I just uploaded 17.1 and it wont even open , it has downloaded ok windows verifies it but just wont open I went intoprograms and clicked exe on kodi but nothing? any help
willr Any chance we can get a proper debug log out of you? Pleas try and not double post.
Using an editor copy and paste the code in a file called advancedsettings.xml
<advancedsettings>
<loglevel>2</loglevel> <!-- Change this to "1" to hide the on-screen debug log text -->
</advancedsettings>
Try to launch Kodi, when it fails go into your %APPDATA%\Kodi\kodi.log or if you have a windows store version %LOCALAPPDATA%\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalCache\Roaming\Kodi\kodi.log and copy that log using copy & paste, go to pastebin.com and post it, save the link at the top of the page and post it in this thread. I'm sure you don't have banned add-ons so it's likely your issue will get a response.
Log file/Advanced (wiki)
10:14:52.902 T:1596 NOTICE: special://profile/ is mapped to: special://masterprofile/
10:14:52.902 T:1596 NOTICE: -----------------------------------------------------------------------
10:14:52.902 T:1596 NOTICE: Starting Kodi (17.1 Git:20170320-fc1619b). Platform: Windows NT x86 32-bit
10:14:52.902 T:1596 NOTICE: Using Release Kodi x32 build
10:14:52.902 T:1596 NOTICE: Kodi compiled Mar 20 2017 by MSVC 190024215 for Windows NT x86 32-bit version 10.0 (0x0A000000)
10:14:52.902 T:1596 NOTICE: Running on Gigabyte Technology Co., Ltd. device with Windows 10, kernel: Windows NT x86 64-bit version 10.0
10:14:52.903 T:1596 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
10:14:52.903 T:1596 NOTICE: Host CPU: Unknown, 4 cores available
10:14:52.903 T:1596 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
10:14:52.903 T:1596 NOTICE: Running with restricted rights
10:14:52.904 T:1596 NOTICE: Aero is enabled
10:14:52.904 T:1596 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
10:14:52.904 T:1596 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
10:14:52.904 T:1596 NOTICE: special://xbmcbinaddons/ is mapped to: C:\Program Files (x86)\Kodi/addons
10:14:52.904 T:1596 NOTICE: special://masterprofile/ is mapped to: C:\Users\Will\AppData\Roaming\Kodi\userdata
10:14:52.904 T:1596 NOTICE: special://home/ is mapped to: C:\Users\Will\AppData\Roaming\Kodi\
10:14:52.904 T:1596 NOTICE: special://temp/ is mapped to: C:\Users\Will\AppData\Roaming\Kodi\cache
10:14:52.904 T:1596 NOTICE: special://logpath/ is mapped to: C:\Users\Will\AppData\Roaming\Kodi\
10:14:52.904 T:1596 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\kodi.exe
10:14:52.907 T:1596 NOTICE: Local hostname: Will-PC
10:14:52.907 T:1596 NOTICE: Log File is located: C:\Users\Will\AppData\Roaming\Kodi\/kodi.log
10:14:52.907 T:1596 NOTICE: -----------------------------------------------------------------------
10:14:52.910 T:1596 NOTICE: load settings...
10:14:52.915 T:1596 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
10:14:52.915 T:1596 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
10:14:52.918 T:1596 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
10:14:52.918 T:1596 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
10:14:52.918 T:1596 NOTICE: Default Video Player: VideoPlayer
10:14:52.918 T:1596 NOTICE: Default Audio Player: paplayer
10:14:52.918 T:1596 NOTICE: Disabled debug logging due to GUI setting. Level 0.
10:14:52.918 T:1596 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
10:14:52.918 T:1596 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
10:14:52.918 T:1596 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
10:14:52.919 T:1596 NOTICE: Loaded playercorefactory configuration
10:14:52.919 T:1596 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
10:14:52.919 T:1596 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
10:14:52.926 T:1596 ERROR: SQL: [Addons27.db] SQL error or missing database
Query: SELECT idVersion FROM version
Go to the following directory...
C:\Users\Will\AppData\Roaming\Kodi\userdata\database.
In that directory you will see a file named Addons27.db. If you look at the file size, you will see it is 0kb
Delete it and restart Kodi. It should work. If not just reboot and try again.
