first of all i am new to this forum my name is kevin i have used jarvis for ever and just updated to kripton i have a problem that there is no addon button within the home screen so at the moment i cannot install any addons i i really need some help i can post a screen shot if this will help
In Estuary, the addon section is accessable in the left sidemenu.
If you enter it, check out the addon section in the upper left of the screen
update i went to the settings and found these buttons were not enabled once enabled they magically appeared so problem fixed thanks to all that looked into this
Not quite sure what addon button you were looking for there,but glad you found it :-)
\edit just realised you might be talking about homescreen shortcuts...
