Full Version: La Femme Nikita TV scraper / library issues
I'm converting over from Media Center .. slowly ...... so there's a lot of "stuff" in the kodi error log that I had to chop out to fit in 512k.
La Femme Nikita is on a shared drive with folder / filename
La Femme Nikita (en)
{I have also tried La Femme Nikita (1997) with no luck - different error messages though}
underneath are ISOs
La Femme Nikita (en)_S01E01E02E03.ISO
La Femme Nikita (en)_S04E05E06E07.ISO
all the way through Season 5.
Here's my pastebin La Femme Nikita
remove the (en) from both the directory name and iso name. It is not required
Everything else looks spot on.
oh, I also noticed that no-one has completed the DVD listing information on the site. Except for season 1 where half the episodes have it and the other half do not.
Best procedure in that case is to scrape by Aired Order, or you will have problems with Season 1 with only half the info being completed. Or you could request the Moderators at the TVDB site to fill in the missing data, but it might take a couple of weeks.
You just need to check that the DVD order is the same as the Aired order.
