2017-04-05, 14:55
2017-04-05, 15:31
Have the same issue on Anroid.Any idea on how solve it on android.Cleared cache,Force stopped the app and restarted but no luck.Tried to find anythng related to addon27.db in /data/data/org.xbmc.kodi but no luck.
2017-04-05, 16:58
Thread split and moved to Android
2017-04-05, 17:14
Not sure if the Stick works this way but other Android boxes have the Android apps within the Kodi Program tab. There you can select Android or Program addons. If you select Android addons, you should have access to ES Explorer or any other Android apps.
