I´m running android tv box based on S905 chip and Kodi 17.1. My problem is that I cant change resolution in Kodi. It always appears gray out. I have TV capable of 4k and resolution in Kodi is 1080p. Does any of you have an idea where can be problem?
Secondly I´m not able to play 2160p x265 10 bit video - its slideshow. However in Vidon player it works smoothly. Do you have any idea?
Do not worry about it. The resolution setting is for Kodi UI only and it is indeed fixed for Android. All the video data is sent as is, so you will watch your videos in their original resolution, possibly scaled to the TVs native resolution. You can see the actual video file resolution in Video properties while a video is playing.
As to your second question: you should provide debug logs and describe your video source exactly.
Log file:
https://mega.nz/#!qhpEBCqQ!NBoxq-Q4gyevC...a5lFM-qOqQ
Video:
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main
[email protected]@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2h 0mn
Bit rate : 6 014 Kbps
Width : 3 840 pixels
Height : 1 600 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.041
Stream size : 5.05 GiB (84%)
Writing library : x265 1.9+140-34a3d35c5f97:[Windows][GCC 5.3.0][64 bit] 10bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=15 / lookahead-slices=8 / bframes=4 / bframe-bias=0 / b-adapt=0 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=2 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / no-rd-refine / signhide / deblock=0:0 / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=2 / pass / bitrate=6015 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
