2017-04-06, 14:59
I have tried Windows 7 & 10 but the issue is the same. Running Kodi with my GTX 560M just results in crashing when I try to launch Kodi. I do have an integrated graphics (intel HD 3000) that works great with Kodi, but I do not understand what's the problem with the GTX 560M.
I enabled "Debug" and I installed "Kodi logfile uploader" and enabled "Post old logfile"
This is what I did.
- Installed Kodi, launch it with my integrated graphics, enabled debug and installed "Kodi logfile uploader" and enabled "Post old logfile. I exited Kodi and opened it with my GPU. it then crashes and I clicked close. I then launched it again with my integrated graphics and opened "Kodi logfile uploader" and I got two links.
https://paste.ubuntu.com/24327425
https://paste.ubuntu.com/24327428
Also in "C:\Users\username\AppData\Roaming\Kodi" I can see a "Kodi crashlog" in a DMP file. Not sure if that would help with anything.
I have no 3rd party addonds. everything is as fresh as it can get.
I have had similar problems on another system with Windows 10 that has the GPU AMD HD 5450 where it will crash 9/10 times at startup if I select it as a startup when I start my PC. Sometimes it will crash during session but using Linux it has no problems what so ever. So I'm not sure if it's a GPU problem or a Windows problem. Both?
This is what I did.
