Hello all,
I seem to be caught in an endless loop error. I am running kodi 17 Osmc on a rasp pi3 running the titan krypton beta skin. I was using the Netflix vertical 2 layout before i update. After the update to kodi 17, when I attempted to change a widget, I get a "skin shortcuts - unable to build menu error every single time I navigate away from the home screen and go back.
Log:
https://pastebin.com/RYuSvQ3s
have i been blacklisted or something?
(2017-04-14, 21:05)spigot666 Wrote: [ -> ]have i been blacklisted or something?
Nope, it's just that Marcel is currently absent and no one else is familiar with the skin in detail.
- do you have got the latest skinshortcuts installed ?
https://github.com/marcelveldt/repositor...1.0.17.zip
- there have been several issues with widgets and menu items during the past few weeks, search the forum and/or try to build the whole widgets and menu from scratch, that means deleting everything you customized until now and set it up again..
Awesome, ty for the reply. I didnt have the most recent version of skinshortcuts installed. I installed the zip, but same result.
Thats basically what I was trying to do, but I cant even build anything from scratch because im stuck with the title error every time it attemps to build the home menu. Not sure how I can start from scratch at this point without a full reinstall, which I would reaaaaaalllly like to avoid.
(2017-04-19, 22:35)spigot666 Wrote: [ -> ]Awesome, ty for the reply. I didnt have the most recent version of skinshortcuts installed. I installed the zip, but same result.
Looking at your log it seems that your skinshortcuts config files are corrupt. You will need to reset your shortcuts to defaults.
I am experiencing the same issue. 4 Have you ever found an answer? If so please share.
I had the same error resetting shortcuts to default worked for me. Only took a few minutes to set up my settings and back to awesomeness.
