Full Version: Multiple sources for single movie,Stack HD,SD movies with context menu to choose
after doing some research about this topic, I found some forums regarding this and i would like to know if it will implemented on kodi 18.
forums references:
Multiple sources for single movie (different quality): http://forum.kodi.tv/showthread.php?tid=135178
Feature Request - Stack HD and SD movies with context menu to choose which to play: http://forum.kodi.tv/showthread.php?tid=218236
Managing several version of a movie: https://forum.libreelec.tv/thread-436.html
as well an AI scrap that can get info not only from file names but also from files itself, such as, run time, code, bit rate, etc.
forums references:
Clean scraping API: http://forum.kodi.tv/showthread.php?tid=134012
main idea will be to add movies/ tv show from different sources (ftp, etc) to library, and combine same/duplicates movies (different quality, versions) into only one item in library, with a pop up menu allowing to chose between different quality/audio (2d, 3d, english, spanish audio etc). thank you
I'm confused. What does this have to do with google summer of code?
(2017-04-07, 14:59)natethomas Wrote: [ -> ]I'm confused. What does this have to do with google summer of code?
ok just delete it
