I am running kodi 16.1 (win 10). how do I clean my box and reload with 17.1
You have a box with win 10? If you really want to start allover just remove Kodi, remove the userdata folder if that's not done automatically and install version 17
you'll find the userdata folder here: %appdata%\kodi\ (just open in explorer)
If you use the Kodi uninstaller there is an option to remove the "Profile Folder" This will completely remove Kodi and ALL your data!
