Downloaded newest kodi, always has worked before. Installed and evrytime I goto open it it crashes, doesn't even open at all. Keep getting last time koi opened, it unexpectedly quit. Do you want to try and reopen windows again. No matter what I do it happens everytime. Never had this problem with any other versions of kodi. Any help would be highly appreciated. Thanks.
also running mac os10.10.5.
st login: Mon Apr 10 13:24:28 on console
BeastModes-MBP:~ BeastMode$ /Applications/Kodi\ 5.app/Contents/MacOS/Kodi ; exit;
sh: /Applications/Kodi: No such file or directory
libc++abi.dylib: terminating with uncaught exception of type dbiplus:
bErrors
Abort trap: 6
logout
[Process completed]
shows in terminal
You renamed Kodi.app to "Kodi 5.app"? What if you rename it back to Kodi.app - which is the name it comes. Renaming the app might freak apples internal self signing out and result in other weired things.
tried everything, and renamed it also still no luck.....cant even open it to get to debug log
Yeah it has to be called kodi.app or things will go wrong ive been playing with the portable install and it just wont work with MAC due to this very fact for one.
