Full Version: [Solved] path substitution of parent path
hi guys
been searching forum for an answer for this
i have playlists on my synology nas that are formatted as m3u lists
they individual path for each item is as follows
../the library/artist/album/song.ext
i already have a sub for the playlist folder
special://playlist (however it is formatted)
to smb://nas/music/playlists
i find that i cant play m3u unless i change the path to //nas/music/the library
can i path sub a ../the library and then change it to
smb://nas/music/the library?
im concerned it wont like the ../ part of the path...
i would like to avoid changing the path in the file itself as it break the audio station in synology
as background i have the library as a source for music in kodi as well, not sure that helps or is of no meaning
Why not go ahead and try?
My m3u paths start with /rootfolder/...
I path substitute: /rootfolder/
to: nfs://192.168.1.6/Volume1/rootfolder/
and that works ok.
ill give it a shot when i get home and see how it goes.....
if it does work im sure it could make life easier for alot of people who run combined systems....as im sure that something alot of us will be doing over the next few years with connected homes and intergration
<pathsubstitution>
<substitute>
<from>special://masterprofile/playlists/music</from>
<to>smb://10.0.0.1/music/playlists/</to>
</substitute>
<substitute>
<from>../The Library/</from>
<to>smb://10.0.0.1/music/The Library/</to>
</substitute>
</pathsubstitution>
have uploaded to kodi, but am unable to test till i get home....
so as a note for everyone else who wants to look at doing this ../folder/ redirection does work
it works perfectly,
so i now can use relative m3u paths that use parent directory marking to share playlists accross mutiple devices
