2017-04-12, 06:44
2017-08-04, 21:30
unless you haven't done it already try v1.0.12 from https://github.com/idleloop-github/xbmc-...m/releases, works fine with Kodi 17.4RC
2017-08-05, 16:31
(2017-08-04, 21:30)bkuhls Wrote: [ -> ]Hi,
My Android R-Box has older Android OP System that Kodi 17 does not work with, so I am stuck using Vrs 16.1..
Is there anyway to get my EarthCam back with Kodi 16.1 ? ..
I like my old Android OP System better then newer vrs, also ..
Be nice if the Gu-Ru's would put new 17 improvements in Kodi 16.1. Am sure there are a lot of others who would appreciate that, like me!
ctx9
2017-08-07, 16:59
(2017-08-05, 16:31)ctx9 Wrote: [ -> ](2017-08-04, 21:30)bkuhls Wrote: [ -> ]Hi,
ctx9
The gu-rus did better they put 16 into 17... To get the appearance of 16 just go to setting>Interface setting>skin
>Get more
Then u can download confluence which is the default look of 16.
Once u do that u have 16 with all the upgrades of 17.
2017-08-08, 22:41
Any reason this isn't in the official repository?
