I was wondering if I could configure the guide in SimpleIPTV to show as a Widget on the TV tab.
I can't seem to make the guide a Favorite to get the proper command for a custom Widget.
Is this even possible to do?
I think only mine mod have that....some old img
(I am on leia and simpleIPTV dont work in this version, cant take new images)
What mod is that?
Looks like an entire EPG addon...
What I'm looking to do is just add a Widget to the TV Home display that I can quickly scroll through the EPG to see if there is anything to watch without having to load a full screen version...
But it may be a desire the Widget functions simply won't support.
that is widget on home....
Ah...So I take it that is built into the skin itself...
AeonMQ6?
I will have to check it out. I'm currently using Xonfluence.
Hi guys. I have completely modified estuary skin to look like sky q. Sky q is a uk based tv provider.
One of the features on sky q is the tv guide on the main home screen where the widgets would be.
Is there a way of achieving this by putting the PVR TV guide as a widget or placing the TV Guide window as a visible item on the home screen.
Of course it needs to function fully as well.
Any help kindly appreciated. Thanks
(2021-01-27, 10:43)jblackwell1990 Wrote: [ -> ]One of the features on sky q is the tv guide on the main home screen where the widgets would be.
I suspect what you are wanting achieve is not actually possible.
That being said, I do seem to remember that the author of the 'Next Up' addon also created an Estuary skin Mod about 4/5 years ago that did something similar with Live TV on the home screen. I can't remember exactly how he did this, since it was so long ago, but I found the original links to his skin mods here:-
280154 (thread)
or
302373 (thread)
Hopefully, they will still work for you, but Krypton is obviously very old now.
Hope this helps.
(2021-01-27, 15:08)Dumyat Wrote: [ -> ] (2021-01-27, 10:43)jblackwell1990 Wrote: [ -> ]One of the features on sky q is the tv guide on the main home screen where the widgets would be.
280154 (thread)
or
302373 (thread)
Hope this helps.
Thank you for replying. What I am trying to achieve is very similar to what Angelinas has posted above with the pvr guide on the home screen as a widget. I would even be happy with just the few lines from the tv guide. I just need to know how to write the code
