i have been looking for the install from zip file but i cannot find it anywhere, can somne one help please.
If you go to settings-system settings, then select Add-ons Running, then go up a level (select the two dots at the top), then a menu will come up that has it there
(2017-04-16, 11:55)bilgepump Wrote: [ -> ]If you go to settings-system settings, then select Add-ons Running, then go up a level (select the two dots at the top), then a menu will come up that has it there
Exellent answer, just what i needed to know thanks very much
