Thanx for you help but, maybe I didn't explain it correctly:
When I click on the KODI icon the blue circle appears for 3-5 sec... then nothing. I have KODI on a stick & on a Mac Mini, I know what it's suppose to do...but, it's
Please can someone assist me, i have windows 7 professional, i was running Kodi Jarvis perfectly. I then downloaded Krypton. After having issues with installing services packs, i managed to get Kodi to install. when clicking on open Kodi, i get this message: Kodi has stopped working, check online for solution and close the program/ close program. Checking online does nothing and when clicking on the view problem details, the first line says: PROBLEM EVENT NAME: APPCRASH
Please Please help
IceMan311 Read the important sticky post at the top of this forum on exactly that topic.
CurtisG It would be better if you started your own thread, including required debug log, as you have a different issue.
Mine will not start either 17.1 win7x64 try older versions same result do not know how to due a debug log but below are my errors
ERROR: ActiveAE::ActiveAE::CActiveAE::FlushEngine - failed to flush
14:33:34.080 T:2260 ERROR: ActiveAE::ActiveAE::CActiveAE::InitSink - failed to init
14:33:36.580 T:2260 ERROR: ActiveAE::ActiveAE::CActiveAE::FlushEngine - failed to flush
14:33:41.580 T:2260 ERROR: ActiveAE::ActiveAE::CActiveAE::InitSink - failed to init
14:33:44.080 T:2260 ERROR: ActiveAE::ActiveAE::CActiveAE::FlushEngine - failed to flush
14:33:49.080 T:2260 ERROR: ActiveAE::ActiveAE::CActiveAE::InitSink - failed to init
14:33:51.580 T:2260 ERROR: ActiveAE::ActiveAE::CActiveAE::FlushEngine - failed to flush
14:33:56.580 T:2260 ERROR: ActiveAE::ActiveAE::CActiveAE::InitSink - failed to init
14:33:59.080 T:2260 ERROR: ActiveAE::ActiveAE::CActiveAE::FlushEngine - failed to flush
falconltd - follow either of the links already given that describe how to get a debug log. Post it to a public paste site (e.g. pastebin.com) and post the link back here.
Thanx everybody for your help, I followed the instructions from: [Solved] first time user installed 17.1 and kodi wont open...
...and everything is good!!!
falconltd
Just a guess by a n00b...but it looks like your audio settings are messed up. Might check the audio output settings, Nvidia drivers and default settings for Win 7 for the default playback device.
From your log:
37.14:33:21.573 T:2260 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_DTSHD" on device "DELL U3415W-4 (NVIDIA High Definition Audio)" seems to be not supported.
flhthemi Thank you, you where wright fixed audio setting, updated Nvidia drivers works great All fixed
(2017-04-17, 19:28)Mara5 Wrote: [ -> ]Hi,
I would really appreciate it if someone can assist me...
Every time I open Kodi Krypton 17.1, it crashes before I can even do anything. The grey background and Kodi logo would come up. It will even go into the main page Kodi, but after 3 seconds a message saying "Kodi has stopped working and will be forced to closed down" will come up.
http://pastebin.ca/3797961... this is my old log file
http://pastebin.ca/3797965.......this my new
Can someone please assist me. I am not tech savy, so please break down into directions you would like me to do.
And same answer than your previous post:
1- do not hijack thread
2- no support for kodi installation contaminated with
banned addons (wiki)
