2017-04-16, 20:06
Hello,
I wrote a video add-on to access the media library of spanish public television service TelevisiĆ³n EspaƱola (TVE).
Requirements:
beautiful-soup is used and should be installed automatically if not available yet
Furthermore the addon uses Streamlink to decode the streams. You can find the plugin as well as the repo at the following pages:
https://github.com/beardypig/plugin.vide.../releases/
https://github.com/beardypig/repository....s/releases
Known issues:
Saludos, malvinas2
v1.0.2: - added option to enable / disable subtitles in the settings
- increased time-out
- if short-title not available use long-title
http://ul.to/j6g134v0
Requirements:
Known issues:
- for the sake of clarity just complete episodes are displayed. The website also contains videos showing things like trailer, making-of, interviews etc., which are not shown within the addon.
- sorting by date doesn't work. I don't know why as the date specifications are read out correctly. Let me know, if you know a solution.
- In addition to video files a small number of programs also contains audio files, e.g. Ciencia forense, 30 anios sin Felix or Eurovision 2014.
If the program includes a small number of episodes (< 25), the audio files will be filtered out. In case of more episodes the current algorithm fails. Probably a workaround would be possible, but it isn't worth the effort as just a very small percentage of the total videos is affected.
- Video quality can't be configured, the best quality available is chosen instead.
- Last but not least: I am really not a programmer and that's how the code looks like. Suggestions for improvement are always welcome.
Saludos, malvinas2
