I have Samsung galaxy s6. It just upgraded to Nougat. After the upgrade, every time i start Kodi, there is a loud static noise coming from the headphones. Internal speaker works fine. I have disabled "send low noise" option in the audio settings. The loud noise stops being when Kodi starts up, but it appears every time i switch screen or during playback. Any suggestions? Is this a known issue and new versions will address this?
I have a Samsung galaxy tab s2. Since l upgraded to Nougat this morning same sound problem.
So, reading some other posts relating to this. The issue is with Samsung Nugat update, disabling FLOAT in HW driver. I am sure future Kodi builds will address that. At this point, the options are either downgrade to Kodi 16 (that is what I did), or use Blutooth headphones.
This issue doesn't only occur in Kodi. It also happens with Spotify and YouTube.
(2017-05-24, 20:42)Edze123 Wrote: [ -> ]This issue doesn't only occur in Kodi. It also happens with Spotify and YouTube.
Yeah - that's why we don't silently workaround it. We are not Samsung's QA department.
(2017-05-24, 22:36)fritsch Wrote: [ -> ] (2017-05-24, 20:42)Edze123 Wrote: [ -> ]This issue doesn't only occur in Kodi. It also happens with Spotify and YouTube.
Fixed by Samsung in new firmware T813XXU2BQG4 (Galaxy Tab S2) with build date Fri, 07 Jul 2017 12:03:50 +0000
