Full Version: Installed Apptv on amazon fire stick and Kodi loads and then goes black screen.
Hello,
I installed the APP TV skin for Kodi on my Amazon fire stick. After the install, the menu and everything was there, but the menu was running slow so I restarted the stick. when I went back into Kodi, Kodi loaded fine and I got the App TV logo, but after the logo went away the screen goes black. After letting it sit long enough the screensaver kicks in, but there is no way to get Kodi to load now with a menu. Any suggestions?
I was able to force a stop on Kodi through the apps menu and clear the cache, un plugged the stick moved it to another TV, but nothing so far has worked.
Nevermind it was just as easy as to clear the data cache and resinstall the addons, but if you have any info on this or suggestions for the next time i decide to install it please let me know. Thanks
Post a FULL debug log (available from the skins support menu in skin settings menus). Pretty sure I know what the problem is, but debug log will confirm.
Wyrm (AppTV)
(2017-04-21, 10:35)wyrm Wrote: [ -> ]Post a FULL debug log (available from the skins support menu in skin settings menus). Pretty sure I know what the problem is, but debug log will confirm.
Wyrm (AppTV)
I would have loved to send in the debug log. Am I able to still send it since I cleared the data cache and cache and reinstalled all my add ons? I have not tried to reinstall the AppTV since it caused some issues during the first install. This is all new to me and I have only had the stick for a week now.
(2017-04-23, 22:01)wardog Wrote: [ -> ]
Wyrm (AppTV)
Yep, pretty sure it will show where the problem is.
Wyrm (AppTV)
