Full Version: Main menu shortcuts stop working
I notice that when i build a main home screen menu, and add a shortcut to an addon to each menu item, it all works fine.
Although as soon as I add a single sub menu item the main menu shortcuts don't work any more. The sub menu shortcuts work.
This is the case in Jarvis as well as in Krypton version.
I feel it has to do with a third party addon, and I suspect it to be the script Simplejson, but not sure.
Anyone else experience with this?
Please help me to better understand the issue...
So, if you add a new mainmenu item to your menu, add a submenu with only 1 single item, the mainmenu's shortcut doesn't work anymore ?
What homemenu layout are you using ?
Also, make sure that you have not enabled the option "open/focus dubmenu on mainmenu click"
