2008-02-18, 02:03
I'm getting all sorts of problems with recents builds including 720p mkv content that plays way to fast (with no sound coming from the speakers and a crash when i press stop), and crashes when attempting to play anything with AC3 audio (even AC3 speakertest audiofiles). Earlier builds were fine.
I found the following in xbmc.log after the 720p mkv crash:
With a lot of repeats of the last two lines. Havent really pinpointed this to a specific revision, but will try to do so.
Quote:00:19:03 T:2826468240 M:101117952 NOTICE: Creating audio device with codec id: 86020, channels: 2, sample rate: 48000, pass-through
00:19:03 T:2826468240 M:101117952 DEBUG: CALSADirectSound::CALSADirectSound - opening alsa device
00:19:03 T:2826468240 M:100773888 DEBUG: CALSADirectSound - using alsa device default:AES0=6
00:19:03 T:2826468240 M:100773888 ERROR: CALSADirectSound - pcm_open_lconf, alsa error: No such file or directory
00:19:03 T:2826468240 M:100773888 ERROR: CALSADirectSound::AddPackets - sanity failed. no valid play handle!
00:19:03 T:2826468240 M:100773888 DEBUG: CDVDPlayerAudio:: Resync - clock:0.000000, delay:-32000.000000
00:19:03 T:2834860944 M: 91742208 INFO: ffmpeg: [h264] Cannot parallelize deblocking type 1, decoding such frames in sequential order
00:19:03 T:2826468240 M: 91312128 ERROR: CALSADirectSound::AddPackets - sanity failed. no valid play handle!
00:19:03 T:2826468240 M: 91312128 DEBUG: CDVDPlayerAudio:: Discontinuty - was:18952.638000, should be:64000.000000, error:45047.362000
