Full Version: DVD files added multiple times
I am running 16.1 on a Wetek Core drawing files from a Synology NAS. When I scan my movie library it adds each individual DVD-ripped file as separate items. The files seem to conform to the required naming / folder structure; they are in individual folders. I have enabled the movies in separate folder option and recursive search.
If I move the files to a VIDEO_TS folder within their individual movie folder then the movie is, correctly, added once.
When I initially setup the library this problem didn't occur. It was triggered by recreating the library after patching Kodi.
Is anyone else suffering from this issue?
Many thanks,
Tom
Quote:it adds each individual DVD-ripped file as separate items
Quote:If I move the files to a VIDEO_TS folder
I am not completely understanding what you are doing. Can you explain...
1. How are you ripping the DVD's
2. Give an example of one of your movies, showing directory structure, file names and locations. What you think should be happening, and what is actually happening.
