Hello.
I have a grouplist(vertical) filled witth fixedlist(horizontal). The lists is filled with dynamic content.
Can i somehow make ta focused position alway vertically center of screen.
You cant make the grouplist a fixed list if that is what you mean. But if all your fixed lists in the grouplist have the same height - you can make a slide animation for the entire grouplist, which would make the focus container seem fixed
(2017-04-23, 15:00)andersfisker Wrote: [ -> ]You cant make the grouplist a fixed list if that is what you mean. But if all your fixed lists in the grouplist have the same height - you can make a slide animation for the entire grouplist, which would make the focus container seem fixed
im having a problem with my widgets that i think this would correct. i want my widgets to to move around one fixed position in both axis. do you think this would help me achieve this, if so you provide me a little more information.
thanks
