Full Version: Need help to set up VPN in Kodi
Hi
Need some help with setting up VPN.
I have configured the VPN Manager as per instruction in this link.
http://openelec.tv/forum/unofficial-open...t=0#155724
The issue is while testing the connection authentication is failing. Here is the VPN log contents. I can authenticate from the desktop app with same credentials. Any idea what is wrong?
Im using LibreElec latest version.
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:12 2017 WARNING: file '/storage/.kodi/addons/service.vpn.manager/VyprVPN/pass.txt' is group or others accessible
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:12 2017 OpenVPN 2.4.0 armv7ve-libreelec-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [AEAD] built on Feb 26 2017
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:12 2017 library versions: LibreSSL 2.4.4, LZO 2.09
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:12 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]209.99.115.73:1194
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:12 2017 UDP link local: (not bound)
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:12 2017 UDP link remote: [AF_INET]209.99.115.73:1194
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:12 2017 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:16 2017 [in1.vyprvpn.com] Peer Connection Initiated with [AF_INET]209.99.115.73:1194
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:18 2017 AUTH: Received control message: AUTH_FAILED
09:36:19.004 T:1769993120  NOTICE: Wed Apr 19 09:36:18 2017 SIGTERM[soft,auth-failure] received, process exiting
09:36:19.004 T:1769993120  NOTICE: VPN Mgr : (platform.py) <<< VPN log file end
Ask on the LibreElec (or OpenElec) forums.
We do not support VPN add-ons here. Note the "unofficial" word in your link (which is broken by the way, it's been shortened and a bit is missing from it in the middle).
Thread moved to off-topic
