Full Version: How can one add a single movie to tMM?
How can one add a single movie to tMM? So when I copy a new movie to the movie folder and I do not want tMM update the entire content but that new movie only, how could I do it?
When one updates the sources / a source and only a single movie is found tMM completely rebuilds the image cache (after scraping that movie) which lasts half an hour or longer. How could one avoid it / make it faster?
When the movie is in its own folder inside datasource, the it gets imported first, and you could stop the import right after it is vilsible Wink
We'll look into the image caching problem... should not be done always...
Quote:When the movie is in its own folder inside datasource, the it gets imported first, and you could stop the import right after it is vilsible
The last times, if I remember it right, the single movie were in their own folders but they were not shown at the beginning of the import but at the end always.
Quote: We'll look into the image caching problem... should not be done always...
Thank you, I am not sure at the moment whether it occurs each time.
