2017-04-23, 22:28
I have been having a great deal of trouble with Krypton 17.1 on my Android box (2 GB RAM, 32GB storage). Often I get to the splash screen, it then exits saying that it has unfortunately stopped working. There's nothing in kodi.log. I've even tried dropping the addons27.db (which I've read sometimes solves the problem) and that was the wrong move, as then all I got was a black screen. I've tried 2 fresh installs with different builds, and it's useless. After a while, it simply crashes on startup; sometimes if I execute it again it works - for awhile. But after a few days, it dies.
Before you say I should try SPMC (which is supposedly better for Android boxes), I would if I could find a build that was compatible with SPMC 16.6 . But it seems all the builds I could find are migrating to 17.1, and at least the ones I did try (they were set up for Krypton 17.1), would not install properly.
If I could upload my logs somewhere, that would be a start, but upload to where?
Any suggestions? Mike
