Full Version: No Kodi or XBMC file in the Application Support
I have done everything listed in the step by step procedures, but when I go to file manager there is no folder in application support for Kodi or XBMC. I have the listed fault of [Addons27.db] SQL error or missing database in the console app and I can see the previously hidden files, so I know that is working. Also, I have tried viewing the folders in every method from icon to list, etc. I don't know where to go from here.
Most likely you are looking in the wrong Application Support folder. There are two and Apple hides the one you want.
In "Finder" pull down the "Go" menu and select "Go to folder". Copy and paste this into the popup box-
~/Library/Application Support/
You will see the Kodi folder there.
If its not there make sure to run kodi and allow it to make the folder.
