Hi there @"DaLanik" , first of all great work on your addon !
I'm having some troubles though.
What I want to do:
I have 2 yeelight strips behind my tv , and I want to use them for ambilight with your addon in Kodi.
Using Kodi on a Windows HTPC. Its Kodi 17.6
Using your latest repo/addon version.
The 2 yeelight strips have developer/LAN enabled, and they have a static IP through my router. They both work fine in the app and in Domoticz (I disable it in domoticz when I test the addon).
The main problem is: ambilight does not work. The stripes turn on but dont change in color.
I was able to add the stripes and test them, they also worked on video play/stop. But they never did anything with ambilight.
What I tried:
- Multiple reinstallations of the addon
- Multiple deletions of the userdata
- Disabling hardware acceleration
- Discovery of the stripes never worked
- Manually adding the stripes worked, tried to add in multiple orders and changing settings in multiple ways.
- Tried only ambi service on and no yeemee service on. Seemed promosing in the log but ambilight still didnt work. Saw no errors,
- Tried the rendercapture thing but that gave some buffer error in the log.
- Checked the log sometimes, at one point I thought the exception about "screensaver.video" was it. But I checked your python code and it seems you dont need it ?
- I downloaded the repo again and reinstalled it all.
- A lot of Kodi reboots.
- Some Windows reboots. After the last 2 reboots the stripes dont work at all with the yeemee addon. After adding and testing they dont work.
Current status: nothing seems to work anymore after adding bulbs. Testing also fails, and after testing fails it keeps showing the loading screen so I have to kill Kodi. Maybe you can fix that
This is the current log when testing:
normal log
log:
21:29:24.253 T:4432 WARNING: CPythonInvoker(11): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
21:29:46.794 T:4292 ERROR: EXCEPTION: Unknown addon id 'screensaver.video'.
21:29:47.702 T:4432 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.TypeError'>
Error Contents: expected string or buffer
File "C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee\standalone.py", line 438, in <module>
testbulb(1)
File "C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee\standalone.py", line 233, in testbulb
mmm1 = bulbone.testTurnOn()
File "C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee\service.py", line 1055, in testTurnOn
a1 = json.loads(result)["error"]["message"]
File "C:\Program Files (x86)\Kodi\system\python\Lib\json\__init__.py", line 339, in loads
return _default_decoder.decode(s)
File "C:\Program Files (x86)\Kodi\system\python\Lib\json\decoder.py", line 364, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
TypeError: expected string or buffer
21:29:55.710 T:4884 NOTICE: Storing total System Uptime
21:29:55.710 T:4884 NOTICE: Saving settings
21:29:55.714 T:4884 NOTICE: Saving skin settings
21:29:55.715 T:4884 NOTICE: stop all
21:29:55.715 T:4884 NOTICE: stop player
21:29:55.715 T:4884 NOTICE: ES: Stopping event server
21:29:55.715 T:4884 NOTICE: stopping upnp
21:29:55.868 T:4884 NOTICE: CWebServer[8080]: Stopped
21:29:55.902 T:3144 NOTICE: ES: UDP Event server stopped
21:29:56.103 T:4884 NOTICE: clean cached files!
21:30:01.142 T:4884 ERROR: CPythonInvoker(3, C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee\service.py): script didn't stop in 5 seconds - let's kill it
21:30:01.237 T:4884 NOTICE: closing down remote control service
21:30:01.237 T:4884 NOTICE: stopped
21:30:01.438 T:4884 NOTICE: destroy
21:30:01.438 T:4884 NOTICE: unload skin
debug log
log:
21:31:08.603 T:4788 INFO: initializing python engine.
21:31:08.603 T:4788 DEBUG: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): start processing
21:31:08.612 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
21:31:08.746 T:4260 DEBUG: YEEMEE >> YEMME - AMBI PRIORITY >> 1
21:31:08.746 T:4260 DEBUG: YEEMEE >> LOWER BRIGHTNESS ON AMBI PAUSE >> 0
21:31:08.746 T:4260 DEBUG: YEEMEE >> AMBI SMOOTHEN (MS) >> 0
21:31:08.746 T:4260 DEBUG: YEEMEE >> YEMME - AMBI PRECISION >> 0
21:31:08.746 T:4260 DEBUG: YEEMEE >> REPORT ERRORS >> True
21:31:08.746 T:4260 DEBUG: YEEMEE >> NUMBER OF BULBS >> 1
21:31:08.746 T:4260 DEBUG: YEEMEE >> ON AT START >> 0
21:31:08.746 T:4260 DEBUG: YEEMEE >> DISABLE FOR SHORT FILMS >>FALSE<<
21:31:08.746 T:4260 DEBUG: YEEMEE >> ACTIVATION TIME >>OFF<<
21:31:08.746 T:4260 DEBUG: YEEMEE >> MAX BRIGHT DAY >> 100
21:31:08.746 T:4260 DEBUG: YEEMEE >> MAX BRIGHT CIVIL TW >> 100
21:31:08.746 T:4260 DEBUG: YEEMEE >> MAX BRIGHT NAUTIC TW >> 100
21:31:08.746 T:4260 DEBUG: YEEMEE >> MAX BRIGTH NIGHT >> 100
21:31:08.746 T:4260 DEBUG: YEEMEE >> INIT BULB NUM: 1, IP ADDR: 192.168.1.77, MODEL: stripe
21:31:08.746 T:4260 DEBUG: YEEMEE >> NUMBER OF ACTIVE BULBS >> 1
21:31:08.746 T:4260 DEBUG: YEEMEE >> Number Act Int Color Eff Duration
21:31:08.746 T:4260 DEBUG: YEEMEE >> BULB 0 PLAY : >> 0 20 #BA2B2B 0 500
21:31:08.746 T:4260 DEBUG: YEEMEE >> BULB 0 STOP : >> 0 20 #BA2B2B 0 500
21:31:08.746 T:4260 DEBUG: YEEMEE >> BULB 0 PAUSE: >> 0 20 #BA2B2B 0 500
21:31:08.746 T:4260 DEBUG: YEEMEE >> BULB 0 AMBI: >> 1 BIAS: 0
21:31:08.746 T:4260 DEBUG: YEEMEE >> NUMBER OF AMBI BULBS >> 1
21:31:08.746 T:4260 DEBUG: YEEMEE >> NUMBER OF CONTROLLERS >> 0
21:31:08.817 T:4788 DEBUG: -->Python Interpreter Initialized<--
21:31:08.817 T:4788 DEBUG: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): the source file to load is "special://home/addons/service.yeemee/standalone.py" ("C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee\standalone.py")
21:31:08.817 T:4788 WARNING: CPythonInvoker(6): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
21:31:08.824 T:4788 DEBUG: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): setting the Python path to C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee;C:\Program Files (x86)\Kodi\addons\script.module.pil\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.httplib2\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.six\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.uritemplate\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.oauth2client\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.googleapi\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.certifi\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.chardet\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.idna\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.urllib3\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.requests\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.yaml\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.beautifulsoup\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\script.module.xbmcswift2\lib;C:\Users\admin\AppData\Roaming\Kodi\addons\plugin.video.youtube\resources\lib\;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
21:31:08.824 T:4788 DEBUG: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): entering source directory C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee
21:31:08.841 T:2624 DEBUG: ------ Window Deinit (DialogAddonSettings.xml) ------
21:31:08.860 T:4476 DEBUG: YEEMEE >> STANDALONE FINISHED
21:31:08.860 T:4476 INFO: CPythonInvoker(5, C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee\standalone.py): script successfully run
21:31:08.930 T:4476 INFO: Python script stopped
21:31:08.930 T:4476 DEBUG: Thread LanguageInvoker 4476 terminating
21:31:09.596 T:4788 DEBUG: YEEMEE >> STANDALONE STARTED VERSION 4.2 - TEST LIGHTS
21:31:09.598 T:2624 DEBUG: ------ Window Init (DialogConfirm.xml) ------
21:31:09.598 T:2624 INFO: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
21:31:10.583 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
21:31:10.733 T:2624 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
21:31:10.733 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
21:31:10.968 T:2624 DEBUG: ------ Window Deinit (DialogConfirm.xml) ------
21:31:11.030 T:4788 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture 'media\YEE02.png'
21:31:11.034 T:4788 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture 'media\yee_color.png'
21:31:11.064 T:4788 DEBUG: YEEMEE STANDALONE >> INITIALIZING OVERLAY
21:31:11.065 T:4788 DEBUG: YEEMEE >> TEST BULB NR 1
21:31:11.065 T:4788 DEBUG: YEEMEE >> TEST BULB ON
21:31:11.084 T:2624 DEBUG: Activating window ID: 10138
21:31:11.084 T:2624 DEBUG: ------ Window Init (DialogBusy.xml) ------
21:31:27.484 T:2624 DEBUG: CWinEventsWin32::WndProcWindow is active
21:31:27.667 T:2624 DEBUG: CInputManager:rocessMouse: trying mouse action leftclick
21:31:27.916 T:2624 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
21:31:28.034 T:2624 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
21:31:28.034 T:2624 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x0000, modifier: 0x0
21:31:28.035 T:2624 DEBUG: ------ Window Deinit (Pointer.xml) ------
21:31:28.118 T:2624 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
21:31:28.233 T:2624 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
21:31:28.233 T:2624 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x0000, modifier: 0x0
21:31:28.816 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
21:31:28.933 T:2624 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
21:31:28.933 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
21:31:29.366 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
21:31:29.466 T:2624 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
21:31:29.467 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
21:31:29.567 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
21:31:29.650 T:2624 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
21:31:29.650 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
21:31:29.717 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
21:31:29.800 T:2624 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
21:31:29.800 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
21:31:29.866 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
21:31:29.966 T:2624 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
21:31:29.966 T:2624 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
21:31:30.649 T:2624 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:31:30.650 T:2624 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
21:31:30.784 T:2624 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:31:30.900 T:2624 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:31:30.900 T:2624 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
21:31:31.050 T:2624 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:31:31.050 T:2624 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:31:31.051 T:2624 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
21:31:31.167 T:2624 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:31:31.250 T:2624 DEBUG: Previous line repeats 1 times.
21:31:31.250 T:2624 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
21:31:31.333 T:2624 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:31:31.349 T:2624 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:31:31.349 T:2624 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
21:31:31.500 T:2624 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:31:31.533 T:2624 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:31:31.533 T:2624 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
21:31:31.600 T:2624 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
21:31:31.601 T:2624 DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
21:31:31.650 T:2624 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:31:31.717 T:2624 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
21:31:31.800 T:2624 DEBUG: Previous line repeats 1 times.
21:31:31.800 T:2624 DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
21:31:31.916 T:2624 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
21:31:31.933 T:2624 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:31:31.933 T:2624 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
21:31:32.067 T:2624 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:31:32.068 T:4788 DEBUG: YEEMEE >> CONNECT ERROR [Errno 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
21:31:32.072 T:4788 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
testbulb(1)
21:31:32.072 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 5112
21:31:32.083 T:2624 DEBUG: ------ Window Init (DialogNotification.xml) ------
21:31:32.084 T:2624 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:31:32.084 T:2624 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
21:31:32.084 T:2624 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
21:31:32.084 T:2624 DEBUG: CInputManager::OnKey: up (0xf080) pressed, action is Up
21:31:32.150 T:2624 DEBUG: Keyboard: scancode: 0x48, sym: 0x0111, unicode: 0x0000, modifier: 0x0
21:31:32.173 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 1584
21:31:32.200 T:2624 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:31:32.250 T:2624 DEBUG: Keyboard: scancode: 0x5b, sym: 0x0137, unicode: 0x0000, modifier: 0x10
21:31:32.250 T:2624 DEBUG: CInputManager::OnKey: win-leftwindows (0x10f0d6) pressed, action is
21:31:32.274 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3868
21:31:32.375 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2672
21:31:32.402 T:2624 DEBUG: Keyboard: scancode: 0x5b, sym: 0x0137, unicode: 0x0000, modifier: 0x0
21:31:32.403 T:2624 DEBUG: CWinEventsWin32::WndProcWindow is active
21:31:32.403 T:2624 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
21:31:32.478 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4668
21:31:32.579 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4864
21:31:32.680 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4484
21:31:32.781 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4832
21:31:32.802 T:2624 DEBUG: ------ Window Init (Pointer.xml) ------
21:31:32.882 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3620
21:31:32.983 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4312
21:31:33.083 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3648
21:31:33.184 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4552
21:31:33.198 T:860 DEBUG: Thread JobWorker 860 terminating (autodelete)
21:31:33.198 T:4224 DEBUG: Thread JobWorker 4224 terminating (autodelete)
21:31:33.198 T:4376 DEBUG: Thread JobWorker 4376 terminating (autodelete)
21:31:33.198 T:2940 DEBUG: Thread JobWorker 2940 terminating (autodelete)
21:31:33.285 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3940
21:31:33.386 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4384
21:31:33.487 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4044
21:31:33.588 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3880
21:31:33.689 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4272
21:31:33.790 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 5020
21:31:33.891 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3352
21:31:33.993 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3436
21:31:34.193 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3772
21:31:34.294 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3408
21:31:34.394 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 744
21:31:34.495 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4840
21:31:34.596 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 5040
21:31:34.700 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 1656
21:31:34.802 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2996
21:31:34.903 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4760
21:31:35.005 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4512
21:31:35.106 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2088
21:31:35.208 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3636
21:31:35.309 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 1804
21:31:35.410 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2716
21:31:35.510 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 1568
21:31:35.611 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3736
21:31:35.712 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4948
21:31:35.813 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4492
21:31:35.913 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4776
21:31:36.014 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4692
21:31:36.078 T:2624 NOTICE: Storing total System Uptime
21:31:36.078 T:2624 NOTICE: Saving settings
21:31:36.083 T:2624 NOTICE: Saving skin settings
21:31:36.085 T:2624 NOTICE: stop all
21:31:36.085 T:2624 NOTICE: stop player
21:31:36.085 T:2624 DEBUG: CNetwork::NetworkMessage - Signaling network services to stop
21:31:36.085 T:2624 NOTICE: ES: Stopping event server
21:31:36.085 T:2624 DEBUG: CNetwork::NetworkMessage - Waiting for network services to stop
21:31:36.085 T:2624 NOTICE: stopping upnp
21:31:36.086 T:1604 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
21:31:36.087 T:1604 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
21:31:36.115 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2640
21:31:36.173 T:3008 NOTICE: ES: UDP Event server stopped
21:31:36.173 T:3008 DEBUG: Thread EventServer 3008 terminating
21:31:36.175 T:1136 DEBUG: Thread TCPServer 1136 terminating
21:31:36.216 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3928
21:31:36.291 T:2624 NOTICE: CWebServer[8080]: Stopped
21:31:36.291 T:4548 DEBUG: Thread PeripEventScanner 4548 terminating
21:31:36.292 T:4388 DEBUG: Thread PeripBusUSB 4388 terminating
21:31:36.316 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4672
21:31:36.416 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 5112
21:31:36.516 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4372
21:31:36.617 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4728
21:31:36.717 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 1584
21:31:36.785 T:1556 DEBUG: Thread PeripBusCEC 1556 terminating
21:31:36.785 T:4204 DEBUG: Thread PeripBusAddon 4204 terminating
21:31:36.786 T:2624 DEBUG: SECTION:UnloadDll(C:\Program Files (x86)\Kodi\addons\peripheral.joystick\peripheral.joystick.dll)
21:31:36.786 T:2624 INFO: ADDON: Dll Destroyed - Joystick Support
21:31:36.786 T:2624 NOTICE: clean cached files!
21:31:36.786 T:2624 DEBUG: ADDON: Stopping service addons.
21:31:36.817 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4680
21:31:36.917 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3868
21:31:36.985 T:4860 DEBUG: Thread EPGUpdater 4860 terminating
21:31:36.985 T:2212 DEBUG: Thread PVRGUIInfo 2212 terminating
21:31:37.018 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2672
21:31:37.119 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3128
21:31:37.196 T:5008 INFO: CPythonInvoker(1, C:\Users\admin\AppData\Roaming\Kodi\addons\script.xbmcbackup\scheduler.py): script successfully run
21:31:37.196 T:2624 DEBUG: CPythonInvoker(1, C:\Users\admin\AppData\Roaming\Kodi\addons\script.xbmcbackup\scheduler.py): script termination took 402ms
21:31:37.207 T:5008 INFO: Python script interrupted by user
21:31:37.207 T:4260 DEBUG: YEEMEE >> EXIT
21:31:37.207 T:4260 INFO: CPythonInvoker(3, C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee\service.py): script successfully run
21:31:37.207 T:2624 DEBUG: CPythonInvoker(3, C:\Users\admin\AppData\Roaming\Kodi\addons\service.yeemee\service.py): script termination took 1ms
21:31:37.207 T:5008 DEBUG: Thread LanguageInvoker 5008 terminating
21:31:37.208 T:4524 DEBUG: Thread ActiveAE 4524 terminating
21:31:37.213 T:4712 DEBUG: Thread AESink 4712 terminating
21:31:37.215 T:4260 INFO: Python script interrupted by user
21:31:37.215 T:4260 DEBUG: Thread LanguageInvoker 4260 terminating
21:31:37.219 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3892
21:31:37.265 T:2624 NOTICE: closing down remote control service
21:31:37.265 T:2624 NOTICE: stopped
21:31:37.265 T:3748 DEBUG: Thread RemoteControl 3748 terminating
21:31:37.320 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2568
21:31:37.421 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4848
21:31:37.466 T:2624 NOTICE: destroy
21:31:37.466 T:2624 NOTICE: unload skin
21:31:37.466 T:2624 INFO: Unloading old skin ...
21:31:37.467 T:2624 DEBUG: ------ Window Deinit () ------
21:31:37.467 T:2624 DEBUG: ------ Window Deinit (Home.xml) ------
21:31:37.480 T:2624 DEBUG: ------ Window Deinit (Pointer.xml) ------
21:31:37.480 T:2624 DEBUG: ------ Window Deinit (DialogNotification.xml) ------
21:31:37.480 T:2624 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
21:31:37.482 T:2624 DEBUG: CTextureBundleXBT::CloseBundle - Closed bundle
21:31:37.522 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4544
21:31:37.623 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4072
21:31:37.723 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 5104
21:31:37.824 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2684
21:31:37.925 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4084
21:31:38.026 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4500
21:31:38.126 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4700
21:31:38.226 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 5092
21:31:38.327 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 5004
21:31:38.427 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3504
21:31:38.528 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4532
21:31:38.628 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4820
21:31:38.728 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4300
21:31:38.829 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4504
21:31:38.929 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3500
21:31:39.030 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4336
21:31:39.131 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3956
21:31:39.231 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 1400
21:31:39.331 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4964
21:31:39.432 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4836
21:31:39.532 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4252
21:31:39.632 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4684
21:31:39.733 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3628
21:31:39.833 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4140
21:31:39.933 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4480
21:31:40.034 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2692
21:31:40.134 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4912
21:31:40.235 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4264
21:31:40.335 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3452
21:31:40.435 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4268
21:31:40.535 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4872
21:31:40.636 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4756
21:31:40.736 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 652
21:31:40.836 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4668
21:31:40.937 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4864
21:31:41.038 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4484
21:31:41.138 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4832
21:31:41.238 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3620
21:31:41.339 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4312
21:31:41.439 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3648
21:31:41.540 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 860
21:31:41.641 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4224
21:31:41.741 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4376
21:31:41.842 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3624
21:31:41.942 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3716
21:31:42.042 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4208
21:31:42.142 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2396
21:31:42.244 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 4640
21:31:42.344 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 2340
21:31:42.444 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3368
21:31:42.517 T:2624 ERROR: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): script didn't stop in 5 seconds - let's kill it
21:31:42.544 T:4788 INFO: CPythonInvoker(6, special://home/addons/service.yeemee/standalone.py): waiting on thread 3228
21:31:42.654 T:4788 INFO: Python script interrupted by user
21:31:42.654 T:4788 DEBUG: Thread LanguageInvoker 4788 terminating
21:31:42.866 T:2624 NOTICE: unload sections
21:31:42.869 T:2624 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:31:42.876 T:2624 NOTICE: PVRManager - stopping
After this I uninstalled the addon again and deleted the userdata,
Could you help me ? Really want to make this ambilight thing work. Because I can already see, turning them on manually, that I like it
