Okay, I'll try. Tuning is still on now. Could you describe the path to that folder? I can not see SAMBA, do I? I can only see the folders "home mailboxes" like downloads, userdata ...
It is in
Android/data/org.xbmc.kodi/files/.kodi
and then either temp or cache
I'm really sorry, but how do I get exactly to those folders? Best of the PC, I only have a folder on my desktop where I can add any .zip, pictures, etc. Somehow I do not have my day
for now I did not need these folders. it will surely be silly.
I don't know how to do that on LibreELEC, you need some filemanager....
Try RenderCapture debug, toggling hardware acceleration in video setings.
(2018-01-20, 20:14)DaLanik Wrote: [ -> ]It is in
Is that really the way for LibreElec? I'm using this OS as the default, and I do not already have Android in my internal memory. Thanks
Cmon, guys, you have Google, it's not that hard to find out....
I really looked, but I did not find this way, I have to look again ... but I have moved again, I switched off the hardware acceleration and HEUREKA Ambi works (the acceleration just did not help) ... but I turned off the movie to look at the Ambi setting in the add-on I wanted Ultra), turned on the movie again and Ambi did not work
Yeelight is only on my set when I lost my video, otherwise, thanks for your nerves with us
It should be /storage/.kodi/ and then temp or cache etc.
Well, there you see. The hardware acceleration issue was known, could have saved a lot of time, but OK, we found a couple of small bugs that were ironed out
I suggest delete your config for addon, restart Kodi and make config again now that it works.
OK, I'll try
For now, thanks.
v4.23 (TEST REPO)
- Added ceiling4 (Yeelight JIAOYUE 650) lamp
- Rare Libreelec Linux time format bug fix
- Rare lat-lng bug fixed
- Get sunset-sunrise rare bug fixed
- Another small bug fix for date-time
(2018-01-21, 16:38)DaLanik Wrote: [ -> ]Try RenderCapture debug, toggling hardware acceleration in video setings.
I did toggle between the settings but it doesn't seem to work.
https://paste.ubuntu.com/26439643/
Sorry for the trouble.
I'll be trying again this weekend. Hopefully will get some progress thanks for the updates.
(2018-01-22, 21:55)trivi Wrote: [ -> ] (2018-01-21, 16:38)DaLanik Wrote: [ -> ]Try RenderCapture debug, toggling hardware acceleration in video setings.
Strange. this is your log:
Quote:20:46:28.779 T:6832 DEBUG: YEEMEE >> PLAYBACK >>PLAYING<<
20:46:46.782 T:6832 DEBUG: YEEMEE >> PLAYBACK >>STOPPED<<
20:47:11.326 T:6832 DEBUG: YEEMEE >> PLAYBACK >>PLAYING<<
20:48:34.339 T:6832 DEBUG: YEEMEE >> PLAYBACK >>STOPPED<<
20:49:10.202 T:6832 DEBUG: YEEMEE >> PLAYBACK >>PLAYING<<
20:49:23.216 T:6832 DEBUG: YEEMEE >> PLAYBACK >>STOPPED<<
20:49:54.892 T:6832 DEBUG: YEEMEE >> PLAYBACK >>PLAYING<<
20:50:10.451 T:6832 DEBUG: YEEMEE >> PLAYBACK >>STOPPED<<
And this is mine, when I try without real bulb, but as you can see, it is trying to communicate:
Quote:08:48:19 T:11800 NOTICE: YEEMEE >> PLAYBACK >>PLAYING<<
08:48:19 T:11800 NOTICE: YEEMEE >> ACTIVATION TIME ON/OFF: 0
08:48:19 T:6796 NOTICE: YEEMEE >> SERVER >> 172.16.12.69 WAITING FOR CONNECTION...
08:48:20 T:7904 NOTICE: YEEMEE >> LUMIFACTOR IS 100
08:48:29 T:11800 NOTICE: YEEMEE >> CONNECT ERROR timed out
08:48:29 T:11800 NOTICE: YEEMEE >> 192.168.1.200: GET STATE ERROR expected string or buffer
08:48:29 T:11800 NOTICE: YEEMEE >> MESSAGE TO 192.168.1.200: {u'params': [u'power', u'music_on'], u'id': 1, u'method': u'get_prop'}
08:48:51 T:11800 NOTICE: YEEMEE >> CONNECT ERROR [Errno 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
08:48:51 T:11800 NOTICE: YEEMEE >> RESPONSE FROM 192.168.1.200: ,
08:48:51 T:11800 NOTICE: YEEMEE >> PLAYBACK >>PAUSED<<
08:48:51 T:11800 NOTICE: YEEMEE >> ACTIVATION TIME ON/OFF: 0
08:48:51 T:11800 NOTICE: YEEMEE >> PLAYBACK >>RESUMED<<
08:49:23 T:11800 NOTICE: YEEMEE >> PLAYBACK >>STOPPED<<
08:49:23 T:11800 NOTICE: YEEMEE >> ACTIVATION TIME ON/OFF: 0
08:49:23 T:6796 NOTICE: YEEMEE >> SERVER >> CONNECTION FROM: ('172.16.12.69', 52195) ACCEPTED
08:49:23 T:5156 NOTICE: YEEMEE >> SERVER >> NO BULB, CONNECTION FROM ('172.16.12.69', 52195), TERMINATING HANDLER
08:50:23 T:11800 NOTICE: YEEMEE >> SERVER >> STOP SERVER EXCEPTION (THIS IS EXPECTED AND OK): timed out
As you can see, it is at least trying to communicate and then times out. your log doesn't show that it is even trying to contact the bulb.... No server starting, nothing...
