2017-04-26, 11:59
2017-04-27, 13:14
Best guess, you would need to edit the skin.
2017-04-27, 13:57
Context Menu buttons use the font definition Font-ListInfo-Small
This can be edited in the 16x9/Font.xml
However, this font definition is used for a number of elements throughout the skin, so be aware that editing it will also change some other things that use the same font definition.
