Full Version: Selecting filter needs a busy dialog if possible
When you press 'Filter' in a library view, Kodi just freezes a good while until it loads all the nexxesary infos (SQL at least, not sure about native .nfo system).
Can we have a busy dialog or some indication the software hasn't just browned it's pants please Tongue Wink
tia.. Big Grin
Kodi always uses sql, either internal sqlite or mysql.
Ok, a busy dialog is needed as just freezing the computer in shock is a bit 1980s Wink
You should probably open a trac ticket.
https://trac.kodi.tv/
