2008-02-20, 12:14
for the giggles of living on the edge I have all the --enable options set in configure bar for profiling..however after the last svn up the ILiveTV.h file came down which is included by GMythFile.h
first off theres s typo in GMythFile.h so edit the file and replace :
#include "LiveTV.h" with #include "ILiveTV.h"
finally open ILiveTV.h and add:
#pragma once
as the first line of the file, this stops the compiler from including the header file more than once which causes the class to be defined twice making the compiler bork.
Only a small couple of changes that should get it to build.
#pragma once
