2017-05-01, 14:07
[ I did a forum/google search for my error message and couldn't find a solution to this, so posting it here in case it helps someone else ]
Symptoms:
Couldn't install addons
Plex wouldn't download cover art
kodi.log had lots of "ccurlfile:tat - failed: timeout was reached" entries
System:
Ubuntu 16.04
Kodi 17.1
Solution that worked for me
This just randomly started happening, I'm assuming a Ubuntu update I installed upset something somewhere with curl/kodi. Fetching the failed URLs from the command line worked perfectly, so this was a bit of a tricky issue.
I tried disabling ipv6, testing my DNS and changing the resolvers I was using, but given I could fetch the failed files from the command line it seemed unlikely to me that any of these would be the issue.
I found something in the kodi wiki referring to changing the curlclienttimeout.
In ~/.kodi/userdata/advancedsettings.xml I changed the curlclienttimeout from 3 seconds to 30 seconds (perhaps excessive but given it's working now I'm unlikely to experiment) as per http://kodi.wiki/view/Advancedsettings.xml#cache
<curlclienttimeout>30</curlclienttimeout>
This solved my problem.
Symptoms:
System:
Ubuntu 16.04
Kodi 17.1
