(2017-05-02, 22:13)JackTramiel Wrote: [ -> ]Did you check the epg source setting inside the channel management ( PVR Settings ) ? Maybe something went wrong there somehow.
Thank you so much, that helped, there were two wrong channel settings.
Anyway, the second problem still exists: Kodi crashes short after start at about 50% of starts while connecting to PVR server and importing TV Guide. Any idea how to fix this?
This is the log of a crash short after start (is there a way to attach files to a post?):
14:38:21.475 T:5392 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:38:21.475 T:5392 NOTICE: -----------------------------------------------------------------------
14:38:21.475 T:5392 NOTICE: Starting Kodi (17.0 Git:20170201-a10c504). Platform: Windows NT x86 32-bit
14:38:21.475 T:5392 NOTICE: Using Release Kodi x32 build
14:38:21.475 T:5392 NOTICE: Kodi compiled Feb 1 2017 by MSVC 190024210 for Windows NT x86 32-bit version 6.3 (0x06030000)
14:38:21.475 T:5392 NOTICE: Running on Windows 10, kernel: Windows NT x86 64-bit version 10.0
14:38:21.523 T:5392 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
14:38:21.523 T:5392 NOTICE: Host CPU: Unknown, 2 cores available
14:38:21.525 T:5392 NOTICE: Desktop Resolution: 1920x1080 32Bit at 59Hz
14:38:21.525 T:5392 NOTICE: Running with restricted rights
14:38:21.526 T:5392 NOTICE: Aero is enabled
14:38:21.526 T:5392 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
14:38:21.526 T:5392 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
14:38:21.526 T:5392 NOTICE: special://xbmcbinaddons/ is mapped to: C:\Program Files (x86)\Kodi/addons
14:38:21.526 T:5392 NOTICE: special://masterprofile/ is mapped to: C:\Users\Uli\AppData\Roaming\Kodi\userdata
14:38:21.526 T:5392 NOTICE: special://home/ is mapped to: C:\Users\Uli\AppData\Roaming\Kodi\
14:38:21.526 T:5392 NOTICE: special://temp/ is mapped to: C:\Users\Uli\AppData\Roaming\Kodi\cache
14:38:21.526 T:5392 NOTICE: special://logpath/ is mapped to: C:\Users\Uli\AppData\Roaming\Kodi\
14:38:21.526 T:5392 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
14:38:21.529 T:5392 NOTICE: Local hostname: DeepThought
14:38:21.529 T:5392 NOTICE: Log File is located: C:\Users\Uli\AppData\Roaming\Kodi\/kodi.log
14:38:21.529 T:5392 NOTICE: -----------------------------------------------------------------------
14:38:22.739 T:5392 NOTICE: load settings...
14:38:22.749 T:5392 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
14:38:22.749 T:5392 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
14:38:22.761 T:5392 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
14:38:22.762 T:5392 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
14:38:22.762 T:5392 NOTICE: Default Video Player: VideoPlayer
14:38:22.762 T:5392 NOTICE: Default Audio Player: paplayer
14:38:22.762 T:5392 NOTICE: Disabled debug logging due to GUI setting. Level 0.
14:38:22.762 T:5392 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
14:38:22.762 T:5392 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
14:38:22.765 T:5392 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:38:22.802 T:5392 NOTICE: Loaded playercorefactory configuration
14:38:22.802 T:5392 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:38:22.802 T:5392 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:38:23.078 T:5392 NOTICE: Running database version Addons27
14:38:24.707 T:5392 NOTICE: ADDONS: Using repository repository.xbmc.org
14:38:24.707 T:5392 NOTICE: ADDONS: Using repository repository.kodinerds
14:38:24.707 T:5392 NOTICE: ADDONS: Using repository repository.kodinerds_WIN_32
14:38:24.707 T:5392 NOTICE: ADDONS: Using repository repository.xstream
14:38:24.737 T:3632 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_DTSHD" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
14:38:24.737 T:3632 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_TRUEHD" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
14:38:24.738 T:3632 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_EAC3" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
14:38:24.768 T:3632 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_DTS" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
14:38:24.768 T:3632 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: stream type "STREAM_TYPE_AC3" on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
14:38:24.771 T:3632 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "AMD HDMI Output (AMD High Definition Audio Device)" seems to be not supported.
14:38:24.804 T:3632 NOTICE: Found 2 Lists of Devices
14:38:24.804 T:3632 NOTICE: Enumerated DIRECTSOUND devices:
14:38:24.804 T:3632 NOTICE: Device 1
14:38:24.804 T:3632 NOTICE: m_deviceName : {64BADE6A-9D77-4500-A00E-A18536C036ED}
14:38:24.804 T:3632 NOTICE: m_displayName : HDMI - AMD HDMI Output (AMD High Definition Audio Device)
14:38:24.804 T:3632 NOTICE: m_displayNameExtra: DIRECTSOUND: AMD HDMI Output (AMD High Definition Audio Device)
14:38:24.804 T:3632 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
14:38:24.804 T:3632 NOTICE: m_channels : FL,FR
14:38:24.804 T:3632 NOTICE: m_sampleRates : 48000
14:38:24.804 T:3632 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_RAW
14:38:24.804 T:3632 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
14:38:24.804 T:3632 NOTICE: Device 2
14:38:24.804 T:3632 NOTICE: m_deviceName : {FA271D72-45FC-4156-9926-7030A2131C70}
14:38:24.804 T:3632 NOTICE: m_displayName : Speakers - Lautsprecher (Realtek High Definition Audio)
14:38:24.804 T:3632 NOTICE: m_displayNameExtra: DIRECTSOUND: Lautsprecher (Realtek High Definition Audio)
14:38:24.804 T:3632 NOTICE: m_deviceType : AE_DEVTYPE_PCM
14:38:24.804 T:3632 NOTICE: Device 3
14:38:24.804 T:3632 NOTICE: m_deviceName : default
14:38:24.804 T:3632 NOTICE: m_displayName : default
14:38:24.804 T:3632 NOTICE: Enumerated WASAPI devices:
14:38:24.804 T:3632 NOTICE: m_displayNameExtra: WASAPI: AMD HDMI Output (AMD High Definition Audio Device)
14:38:24.804 T:3632 NOTICE: m_sampleRates : 192000,48000,44100,32000
14:38:24.804 T:3632 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_RAW
14:38:24.804 T:3632 NOTICE: m_streamTypes : STREAM_TYPE_DTSHD,STREAM_TYPE_TRUEHD,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512,STREAM_TYPE_AC3
14:38:24.804 T:3632 NOTICE: m_displayNameExtra: WASAPI: Lautsprecher (Realtek High Definition Audio)
14:38:24.804 T:3632 NOTICE: m_sampleRates : 192000,96000,48000,44100
14:38:25.247 T:5392 NOTICE: Found screen: Generic PnP Monitor on AMD Radeon HD 5450, adapter 0.
14:38:25.247 T:5392 NOTICE: Primary mode: 1920x1080@ 59.94 - Full Screen
14:38:25.323 T:5392 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
14:38:25.323 T:5392 NOTICE: Additional mode: 640x480@ 72.00 - Full Screen
14:38:25.323 T:5392 NOTICE: Additional mode: 640x480@ 67.00 - Full Screen
14:38:25.323 T:5392 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
14:38:25.323 T:5392 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
14:38:25.323 T:5392 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
14:38:25.323 T:5392 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
14:38:25.323 T:5392 NOTICE: Additional mode: 720x576@ 59.94 - Full Screen
14:38:25.324 T:5392 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
14:38:25.324 T:5392 NOTICE: Additional mode: 720x576@ 59.94 - Full Screen
14:38:25.324 T:5392 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
14:38:25.324 T:5392 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
14:38:25.325 T:5392 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
14:38:25.325 T:5392 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
14:38:25.325 T:5392 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
14:38:25.325 T:5392 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
14:38:25.325 T:5392 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
14:38:25.325 T:5392 NOTICE: Additional mode: 1152x648@ 59.94 - Full Screen
14:38:25.325 T:5392 NOTICE: Additional mode: 1152x648@ 60.00 - Full Screen
14:38:25.325 T:5392 NOTICE: Additional mode: 1152x648@ 50.00 - Full Screen
14:38:25.326 T:5392 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
14:38:25.326 T:5392 NOTICE: Additional mode: 1152x864@ 59.94 - Full Screen
14:38:25.326 T:5392 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
14:38:25.326 T:5392 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
14:38:25.327 T:5392 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
14:38:25.327 T:5392 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
14:38:25.327 T:5392 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
14:38:25.327 T:5392 NOTICE: Previous line repeats 2 times.
14:38:25.327 T:5392 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
14:38:25.327 T:5392 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
14:38:25.328 T:5392 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
14:38:25.328 T:5392 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
14:38:25.328 T:5392 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
14:38:25.328 T:5392 NOTICE: Additional mode: 1440x900@ 75.00 - Full Screen
14:38:25.328 T:5392 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
14:38:25.328 T:5392 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
14:38:25.329 T:5392 NOTICE: Previous line repeats 2 times.
14:38:25.329 T:5392 NOTICE: Additional mode: 1600x1200@ 60.00 - Full Screen
14:38:25.329 T:5392 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
14:38:25.329 T:5392 NOTICE: Additional mode: 1776x1000@ 59.94 - Full Screen
14:38:25.329 T:5392 NOTICE: Additional mode: 1776x1000@ 60.00 - Full Screen
14:38:25.329 T:5392 NOTICE: Additional mode: 1776x1000@ 50.00 - Full Screen
14:38:25.329 T:5392 NOTICE: Additional mode: 1776x1000@ 29.97 - Full Screen
14:38:25.329 T:5392 NOTICE: Additional mode: 1776x1000@ 30.00 - Full Screen
14:38:25.330 T:5392 NOTICE: Additional mode: 1776x1000@ 29.97i - Full Screen
14:38:25.330 T:5392 NOTICE: Additional mode: 1776x1000@ 30.00i - Full Screen
14:38:25.330 T:5392 NOTICE: Additional mode: 1776x1000@ 25.00 - Full Screen
14:38:25.330 T:5392 NOTICE: Additional mode: 1776x1000@ 25.00i - Full Screen
14:38:25.330 T:5392 NOTICE: Additional mode: 1776x1000@ 24.00 - Full Screen
14:38:25.330 T:5392 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
14:38:25.330 T:5392 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
14:38:25.330 T:5392 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
14:38:25.330 T:5392 NOTICE: Additional mode: 1920x1080@ 29.97 - Full Screen
14:38:25.331 T:5392 NOTICE: Additional mode: 1920x1080@ 30.00 - Full Screen
14:38:25.331 T:5392 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
14:38:25.331 T:5392 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
14:38:25.331 T:5392 NOTICE: Additional mode: 1920x1080@ 25.00 - Full Screen
14:38:25.331 T:5392 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
14:38:25.331 T:5392 NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
14:38:25.331 T:5392 NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
14:38:25.332 T:5392 NOTICE: Checking resolution 16
14:38:27.230 T:3816 NOTICE: Running database version Addons27
14:38:27.236 T:3816 NOTICE: Running database version ViewModes6
14:38:27.300 T:3816 NOTICE: Running database version Textures13
14:38:27.324 T:3816 NOTICE: Running database version MyMusic60
14:38:27.355 T:3816 NOTICE: Running database version MyVideos107
14:38:27.403 T:3816 NOTICE: Running database version TV29
14:38:27.442 T:3816 NOTICE: Running database version Epg11
14:38:27.984 T:5392 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
14:38:28.057 T:5392 ERROR: Control 15100 in window 12600 has been asked to focus, but it can't
14:38:28.085 T:5392 NOTICE: initialize done
14:38:28.085 T:5392 NOTICE: Running the application...
14:38:28.088 T:5392 NOTICE: CWebServer[8080]: Started
14:38:28.088 T:5392 NOTICE: starting upnp client
14:38:28.139 T:6124 NOTICE: ES: Starting UDP Event server on port 9777
14:38:28.139 T:6124 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
14:38:30.523 T:3816 ERROR: CCurlFile::Open failed with code 404 for
http://raw.github.com/Lynx187/xStreamRep...ns.xml.md5
14:38:30.523 T:3816 ERROR: XFILE::CFileCache::Open - failed to open source <http://raw.github.com/Lynx187/xStreamRepo/master/addons.xml.md5>
14:38:30.523 T:3816 ERROR: CRepository: failed read 'http://raw.github.com/Lynx187/xStreamRepo/master/addons.xml.md5'
14:38:31.966 T:864 ERROR: PVR - PVR::CPVRClients::ConnectionStateChange - invalid handler data
14:38:31.967 T:864 NOTICE: PVRManager - stopping
14:38:34.354 T:764 NOTICE: EPG::CEpgContainer::Start - EPG thread started
14:38:34.354 T:864 ERROR: CThread::Create - fatal error creating thread EPGUpdater - old thread id not null
