Full Version: Cannot detect isPlaying() when using xbmcplugin.setResolvedUrl()
when using code below sometimes playback is failed with message "skipping unplayable item"
xbmc.Player().play(url, listitem)
but if using xbmcplugin.setResolvedUrl(...) it running smoothly, but the problem I can't detect playback status using xbmc.Player().isPlaying() it always return false. is there any solution?
Solved now....
my bad, I have variable error in while section and didn't detect it because I use block try: ..... except:pass
