Full Version: Xonfluence - import settings to Kodi 17
How is is possible to import my current Xonfluence settings form Jarvis to Krypton? I'd hate to redo all those settings if i don't have to.
Just save the settings.xml file located in userdata/addon_data/skin.xonfuence
Ed.. thanks for the response. ok.. so once i have the file saved and I load it back into the user data file in krypton, where do i go from there? if i go thru and change the skin to xonfluence, will kodi automatically load my saved version?
Yes. As long as you do not have the Xonfluence skin in use. When you switch to the skin it will all be there. As long as the relevant ADDONS are installed for your shortcuts.
ok.. thanks!
