2017-05-04, 05:57
Voice control for the Nvidia Shield and Kodi (Updated) 6/26/2017
Update:
I updated this and I put the instructions on Github
Github
Update:
Github
(2017-05-07, 01:55)hahaikke Wrote: [ -> ]Can you enlighten me on the OMDBAPI part?
(2017-05-09, 23:24)brianf21 Wrote: [ -> ](2017-05-07, 01:55)hahaikke Wrote: [ -> ]Can you enlighten me on the OMDBAPI part?
It would be too difficult to clean up the title as it come from IFTTT. So, I search omdbapi.com first to get a title that I can use to search Kodi.
Example: I say "Monster's Inc." What IFTTT sends to the shield is "monsters inc." If I search Kodi for "monsters inc," the movie won't be found, but if I send it to omdbapi.com, it will return with "Monster's Inc." When I search Kodi for "Monster's Inc." It will find the movie and return the ID of the movie which I will then request Kodi to play.
(2017-05-11, 20:08)hahaikke Wrote: [ -> ](2017-05-09, 23:24)brianf21 Wrote: [ -> ](2017-05-07, 01:55)hahaikke Wrote: [ -> ]Can you enlighten me on the OMDBAPI part?
Yes I understood that but was wondering how to set it up. You now completed your guide so i guess it's covered under the tasker files. One more thing, can i do this with Kodi on a raspberry pi or Mac too?
(2017-06-21, 01:46)retero Wrote: [ -> ]Thank you for posting this. Is there a way to send Play/Pause commands to Android TV instead of just Kodi? I was hoping to use key mappings to trigger standard play/pause to control all media sources.The same would be useful for mute/volume.
(2017-07-18, 01:53)marcsoawesome Wrote: [ -> ]can someone help me with the textfied thingy? what text field ? great tut but you need to be more clear
(2017-08-01, 04:09)brianf21 Wrote: [ -> ](2017-07-18, 01:53)marcsoawesome Wrote: [ -> ]can someone help me with the textfied thingy? what text field ? great tut but you need to be more clear
Inside IFTTT, when you click add ingredient, you will be present with two things to choose, "CreatedAt" or "TextField". You choose TextField. This will be whatever you say to Google Home. Example, if you say "play iron man", the term "iron man" is the text field and will be the phrase IFTTT sends to the shield. I hope this is clearer.
(2017-06-25, 01:36)brianf21 Wrote: [ -> ](2017-06-21, 01:46)retero Wrote: [ -> ]Thank you for posting this. Is there a way to send Play/Pause commands to Android TV instead of just Kodi? I was hoping to use key mappings to trigger standard play/pause to control all media sources.The same would be useful for mute/volume.
Yes, tasker has that feature, but the device needs to be rooted. Have you tried this out yet? I have a lot of people downloading this but few comments.
