Hi all
First all I am new here...
i would like to do some change on kodi XML files
i dont know what of XML files i need to change for do my change (I run KODI 17.1 on windows | Eminence skin )
i want the weather and the clock info show also if i wach video or listen to music... (on the top corner on right side )
what do i need to add or change for do it work??
I post on dev fourm and they tell me to come here
that my post..
http://forum.kodi.tv/showthread.php?tid=...pid2580707
i also try to play with the VideoFullScreen.xml file
and added weather parameter from MyWeather.xml file
and this not work for me
please help
Includes_Furniture.xml
Look for <include name="Furniture_TopBar"> towards the bottom of the file.
there will be a bit inside that include that looks like this:
<control type="group">
<include>Furniture_TopBar_Header</include>
</control>
<include>Furniture_TopBar_Clock</include>
</control>
Move the line <include>Furniture_TopBar_Clock</include> down so it is AFTER the next </control> tag
e.g.
</control>
</control>
Reload the skin and the clock should now always be visible.
Hey
Please you can help me one more time
and guide me how to do the same thing
for show always RSS FEED
many thanks
(2017-05-06, 02:37)jurialmunkey Wrote: [ -> ]Includes_Furniture.xml
</control>
</control>
e.g.
</control>
</control>
Would you be kind to walk me through or explain where exactly in KODI do I find this entry as I would like to make same adjustments as well?
(2017-05-09, 13:22)underwriter Wrote: [ -> ] (2017-05-06, 02:37)jurialmunkey Wrote: [ -> ]Includes_Furniture.xml
</control>
</control>
e.g.
</control>
</control>
you need to go kodi folder
the file location is
on Android Android/data/org.xbmc.kodi/files/.kodi/addons/skin.eminence.2/16x9
on iOS /private/var/mobile/Library/Preferences/Kodi/addons/skin.eminence.2/16x9
on Linux ~/.kodi/addons/skin.eminence.2/16x9
on Mac /Users/<your_user_name>/Library/Application Support/Kodi/addons/skin.eminence.2/16x9
on Windows %APPDATA%\kodi\addons\skin.eminence.2\16x9
and there all XML file
you need to change xml file
and folow jurialmunkey instruction
Thanks a lot guyz1987 for the directives. I'll try that tonight.
</control>
</control>
e.g.
</control>
</control>
Great solution. Is there a way to make this into a service add-on, so it can be used across skins, and not be affected by skin updates?
