Full Version: Problem with iPlayer WWW and osmc 2017.4.1
Hi, I am a newcomer to OSMC. I would like to stream BBC radio stations. I live in the UK.
I installed OSMC 2017.4.1 on a Raspberry Pi 3.
I added the iPlayer WWW add-on.
I eventually found and enabled the InputStream.adaptive (why doesn't the add-on installer configure this dependency?)
When I use the OSMC UI on the console and select Music | Music add-ons | iPlayer | Listen Live | Radio 2 i get a couple of "Cookie load failed" messages followed by "One or more items failed to play Check the log.."
*However*, if I use the Chorus web interface via a browser and select Browser | Music | iPlayer WWW | Listen Live | Radio 2 it plays just fine!
logs:
15:23:23.893 T:1832236016 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
15:23:23.903 T:1937765360 NOTICE: Running database version Addons27
15:23:23.905 T:1937765360 NOTICE: Running database version ViewModes6
15:23:23.908 T:1937765360 NOTICE: Running database version Textures13
15:23:23.919 T:1937765360 NOTICE: Running database version MyMusic60
15:23:23.933 T:1937765360 NOTICE: Running database version MyVideos107
15:23:23.938 T:1937765360 NOTICE: Running database version TV29
15:23:23.940 T:1937765360 NOTICE: Running database version Epg11
15:23:23.942 T:1958604800 NOTICE: start dvd mediatype detection
15:23:24.732 T:1958604800 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:23:25.281 T:1958604800 NOTICE: initialize done
15:23:25.281 T:1958604800 NOTICE: Running the application...
15:23:25.287 T:1958604800 NOTICE: starting zeroconf publishing
15:23:25.287 T:1958604800 NOTICE: CWebServer[8080]: Started
15:23:25.287 T:1958604800 NOTICE: starting upnp client
15:23:25.290 T:1646261232 NOTICE: ES: Starting UDP Event server on port 9777
15:23:25.290 T:1646261232 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
15:23:26.987 T:1734341616 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.weathericons.default/.png
15:23:33.203 T:1752167408 WARNING: CSkinInfo: failed to load skin settings
15:24:37.237 T:1958604800 NOTICE: VideoPlayer: Opening: http://a.files.bbci.co.uk/media/live/man...o_two.m3u8
15:24:37.237 T:1958604800 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
15:24:37.261 T:1465037808 NOTICE: Creating InputStream
15:24:37.455 T:1465037808 ERROR: AddOnLog: InputStream Adaptive: Could not open / parse mpdURL (http://a.files.bbci.co.uk/media/live/man...o_two.m3u8)
15:24:37.456 T:1465037808 ERROR: CVideoPlayer::OpenInputStream - error opening [http://a.files.bbci.co.uk/media/live/man...o_two.m3u8]
15:24:37.456 T:1465037808 NOTICE: CVideoPlayer::OnExit()
15:24:37.456 T:1958604800 ERROR: Playlist Player: skipping unplayable item: 2, path [plugin://plugin.video.iplayerwww/?url=bbc_radio_two&mode=213&name=BBC+Radio+2&iconimage=%2Fhome%2Fosmc%2F.kodi%2Faddons%2Fplugin.video.iplayerwww%2Fmedia%2Fbbc_radio_two.png&description=&subtitles_url=&logged_in=False]
15:24:37.780 T:1481815024 WARNING: Attempt to use invalid handle 3
15:24:39.579 T:1958604800 WARNING: Previous line repeats 2 times.
15:24:39.579 T:1958604800 NOTICE: CVideoPlayer::CloseFile()
15:24:39.579 T:1958604800 NOTICE: VideoPlayer: waiting for threads to exit
15:24:39.579 T:1958604800 NOTICE: VideoPlayer: finished waiting
15:24:39.579 T:1958604800 NOTICE: VideoPlayer: Opening: http://a.files.bbci.co.uk/media/live/man...three.m3u8
15:24:39.604 T:1456649200 NOTICE: Creating InputStream
15:24:39.674 T:1456649200 ERROR: AddOnLog: InputStream Adaptive: Could not open / parse mpdURL (http://a.files.bbci.co.uk/media/live/man...three.m3u8)
15:24:39.674 T:1456649200 ERROR: CVideoPlayer::OpenInputStream - error opening [http://a.files.bbci.co.uk/media/live/man...three.m3u8]
15:24:39.674 T:1456649200 NOTICE: CVideoPlayer::OnExit()
15:24:39.674 T:1958604800 ERROR: Playlist Player: skipping unplayable item: 3, path [plugin://plugin.video.iplayerwww/?url=bbc_radio_three&mode=213&name=BBC+Radio+3&iconimage=%2Fhome%2Fosmc%2F.kodi%2Faddons%2Fplugin.video.iplayerwww%2Fmedia%2Fbbc_radio_three.png&description=&subtitles_url=&logged_in=False]
15:24:39.998 T:1481815024 WARNING: Attempt to use invalid handle 3
15:24:40.325 T:1465037808 WARNING: Attempt to use invalid handle 4
15:24:40.861 T:1481815024 WARNING: Attempt to use invalid handle 3
15:24:41.622 T:1465037808 WARNING: Attempt to use invalid handle 4
15:24:41.903 T:1958604800 NOTICE: CVideoPlayer::CloseFile()
15:24:41.903 T:1958604800 NOTICE: VideoPlayer: waiting for threads to exit
15:24:41.903 T:1958604800 NOTICE: VideoPlayer: finished waiting
15:24:41.903 T:1958604800 NOTICE: VideoPlayer: Opening: http://a.files.bbci.co.uk/media/live/man...ourfm.m3u8
15:24:41.927 T:1442051056 NOTICE: Creating InputStream
15:24:42.001 T:1442051056 ERROR: AddOnLog: InputStream Adaptive: Could not open / parse mpdURL (http://a.files.bbci.co.uk/media/live/man...ourfm.m3u8)
15:24:42.001 T:1442051056 ERROR: CVideoPlayer::OpenInputStream - error opening [http://a.files.bbci.co.uk/media/live/man...ourfm.m3u8]
15:24:42.002 T:1442051056 NOTICE: CVideoPlayer::OnExit()
15:24:42.002 T:1958604800 ERROR: Playlist Player: skipping unplayable item: 4, path [plugin://plugin.video.iplayerwww/?url=bbc_radio_fourfm&mode=213&name=BBC+Radio+4+FM&iconimage=%2Fhome%2Fosmc%2F.kodi%2Faddons%2Fplugin.video.iplayerwww%2Fmedia%2Fbbc_radio_fourfm.png&description=&subtitles_url=&logged_in=False]
15:24:42.326 T:1481815024 WARNING: Attempt to use invalid handle 3
15:24:42.434 T:1465037808 WARNING: Attempt to use invalid handle 4
15:24:43.297 T:1456649200 WARNING: Attempt to use invalid handle 5
15:24:43.941 T:1465037808 WARNING: Attempt to use invalid handle 4
15:24:44.050 T:1481815024 WARNING: Attempt to use invalid handle 3
15:24:44.374 T:1456649200 WARNING: Previous line repeats 1 times.
15:24:44.374 T:1456649200 WARNING: Attempt to use invalid handle 5
15:24:44.702 T:1465037808 WARNING: Attempt to use invalid handle 4
15:24:44.784 T:1958604800 NOTICE: CVideoPlayer::CloseFile()
15:24:44.784 T:1958604800 NOTICE: VideoPlayer: waiting for threads to exit
15:24:44.784 T:1958604800 NOTICE: VideoPlayer: finished waiting
15:24:44.784 T:1958604800 NOTICE: VideoPlayer: Opening: http://a.files.bbci.co.uk/media/live/man...ourlw.m3u8
15:24:44.808 T:1429468144 NOTICE: Creating InputStream
15:24:44.902 T:1429468144 ERROR: AddOnLog: InputStream Adaptive: Could not open / parse mpdURL (http://a.files.bbci.co.uk/media/live/man...ourlw.m3u8)
15:24:44.902 T:1429468144 ERROR: CVideoPlayer::OpenInputStream - error opening [http://a.files.bbci.co.uk/media/live/man...ourlw.m3u8]
15:24:44.902 T:1429468144 NOTICE: CVideoPlayer::OnExit()
15:24:44.902 T:1958604800 ERROR: Playlist Player: skipping unplayable item: 5, path [plugin://plugin.video.iplayerwww/?url=bbc_radio_fourlw&mode=213&name=BBC+Radio+4+LW&iconimage=%2Fhome%2Fosmc%2F.kodi%2Faddons%2Fplugin.video.iplayerwww%2Fmedia%2Fbbc_radio_fourlw.png&description=&subtitles_url=&logged_in=False]
15:24:45.226 T:1456649200 WARNING: Attempt to use invalid handle 5
15:24:45.449 T:1465037808 WARNING: Attempt to use invalid handle 4
15:24:45.557 T:1442051056 WARNING: Attempt to use invalid handle 6
15:24:45.777 T:1456649200 WARNING: Attempt to use invalid handle 5
15:24:46.890 T:1465037808 WARNING: Attempt to use invalid handle 4
15:24:47.220 T:1442051056 WARNING: Previous line repeats 1 times.
15:24:47.220 T:1442051056 WARNING: Attempt to use invalid handle 6
15:24:47.337 T:1456649200 WARNING: Attempt to use invalid handle 5
15:24:47.404 T:1958604800 NOTICE: CVideoPlayer::CloseFile()
15:24:47.405 T:1958604800 NOTICE: VideoPlayer: waiting for threads to exit
15:24:47.405 T:1958604800 NOTICE: VideoPlayer: finished waiting
15:24:47.405 T:1958604800 NOTICE: VideoPlayer: Opening: http://a.files.bbci.co.uk/media/live/man...extra.m3u8
15:24:47.429 T:1481815024 NOTICE: Creating InputStream
15:24:47.509 T:1481815024 ERROR: AddOnLog: InputStream Adaptive: Could not open / parse mpdURL (http://a.files.bbci.co.uk/media/live/man...extra.m3u8)
15:24:47.509 T:1481815024 ERROR: CVideoPlayer::OpenInputStream - error opening [http://a.files.bbci.co.uk/media/live/man...extra.m3u8]
15:24:47.509 T:1481815024 NOTICE: CVideoPlayer::OnExit()
15:24:47.510 T:1958604800 ERROR: Playlist Player: skipping unplayable item: 6, path [plugin://plugin.video.iplayerwww/?url=bbc_radio_four_extra&mode=213&name=BBC+Radio+4+Extra&iconimage=%2Fhome%2Fosmc%2F.kodi%2Faddons%2Fplugin.video.iplayerwww%2Fmedia%2Fbbc_radio_four_extra.png&description=&subtitles_url=&logged_in=False]
15:24:47.834 T:1456649200 WARNING: Attempt to use invalid handle 5
15:24:48.182 T:1442051056 WARNING: Attempt to use invalid handle 6
15:24:48.515 T:1429468144 WARNING: Attempt to use invalid handle 7
15:24:48.965 T:1456649200 WARNING: Attempt to use invalid handle 5
15:24:49.087 T:1442051056 WARNING: Previous line repeats 1 times.
15:24:49.087 T:1442051056 WARNING: Attempt to use invalid handle 6
15:24:50.082 T:1429468144 WARNING: Attempt to use invalid handle 7
15:24:50.148 T:1958604800 NOTICE: CVideoPlayer::CloseFile()
15:24:50.149 T:1958604800 NOTICE: VideoPlayer: waiting for threads to exit
15:24:50.149 T:1958604800 NOTICE: VideoPlayer: finished waiting
15:24:50.149 T:1958604800 NOTICE: VideoPlayer: Opening: http://a.files.bbci.co.uk/media/live/man..._live.m3u8
15:24:50.172 T:1481815024 NOTICE: Creating InputStream
15:24:50.242 T:1481815024 ERROR: AddOnLog: InputStream Adaptive: Could not open / parse mpdURL (http://a.files.bbci.co.uk/media/live/man..._live.m3u8)
15:24:50.243 T:1481815024 ERROR: CVideoPlayer::OpenInputStream - error opening [http://a.files.bbci.co.uk/media/live/man..._live.m3u8]
15:24:50.243 T:1481815024 NOTICE: CVideoPlayer::OnExit()
15:24:50.243 T:1958604800 ERROR: Playlist Player: skipping unplayable item: 7, path [plugin://plugin.video.iplayerwww/?url=bbc_radio_five_live&mode=213&name=BBC+Radio+5+live&iconimage=%2Fhome%2Fosmc%2F.kodi%2Faddons%2Fplugin.video.iplayerwww%2Fmedia%2Fbbc_radio_five_live.png&description=&subtitles_url=&logged_in=False]
15:24:50.566 T:1442051056 WARNING: Attempt to use invalid handle 6
15:24:50.922 T:1465037808 WARNING: Attempt to use invalid handle 8
15:24:51.027 T:1429468144 WARNING: Attempt to use invalid handle 7
15:24:51.680 T:1442051056 WARNING: Attempt to use invalid handle 6
15:24:51.891 T:1465037808 WARNING: Attempt to use invalid handle 8
15:24:51.998 T:1429468144 WARNING: Attempt to use invalid handle 7
15:24:52.732 T:1465037808 WARNING: Attempt to use invalid handle 8
15:24:52.840 T:1429468144 WARNING: Attempt to use invalid handle 7
15:24:52.947 T:1442051056 WARNING: Attempt to use invalid handle 6
15:24:53.020 T:1958604800 WARNING: Previous line repeats 1 times.
15:24:53.020 T:1958604800 NOTICE: CVideoPlayer::CloseFile()
15:24:53.020 T:1958604800 NOTICE: VideoPlayer: waiting for threads to exit
15:24:53.020 T:1958604800 NOTICE: VideoPlayer: finished waiting
15:24:53.021 T:1958604800 NOTICE: VideoPlayer: Opening: http://a.files.bbci.co.uk/media/live/man...extra.m3u8
15:24:53.044 T:1456649200 NOTICE: Creating InputStream
15:24:53.134 T:1456649200 ERROR: AddOnLog: InputStream Adaptive: Could not open / parse mpdURL (http://a.files.bbci.co.uk/media/live/man...extra.m3u8)
15:24:53.135 T:1456649200 ERROR: CVideoPlayer::OpenInputStream - error opening [http://a.files.bbci.co.uk/media/live/man...extra.m3u8]
15:24:53.135 T:1456649200 NOTICE: CVideoPlayer::OnExit()
15:24:53.135 T:1958604800 ERROR: Playlist Player: skipping unplayable item: 8, path [plugin://plugin.video.iplayerwww/?url=bbc_radio_five_live_sports_extra&mode=213&name=BBC+Radio+5+live+sports+extra&iconimage=%2Fhome%2Fosmc%2F.kodi%2Faddons%2Fplugin.video.iplayerwww%2Fmedia%2Fbbc_radio_five_live_sports_extra.png&description=&subtitles_url=&logged_in=False]
15:24:53.459 T:1465037808 WARNING: Attempt to use invalid handle 8
15:24:53.785 T:1429468144 WARNING: Attempt to use invalid handle 7
15:24:53.890 T:1481815024 WARNING: Attempt to use invalid handle 9
15:24:54.545 T:1465037808 WARNING: Attempt to use invalid handle 8
15:24:54.659 T:1481815024 WARNING: Attempt to use invalid handle 9
15:24:55.217 T:1429468144 WARNING: Attempt to use invalid handle 7
15:24:55.540 T:1465037808 WARNING: Previous line repeats 1 times.
15:24:55.540 T:1465037808 WARNING: Attempt to use invalid handle 8
15:24:55.669 T:1481815024 WARNING: Attempt to use invalid handle 9
15:24:55.783 T:1958604800 NOTICE: CVideoPlayer::CloseFile()
15:24:55.783 T:1958604800 NOTICE: VideoPlayer: waiting for threads to exit
15:24:55.783 T:1958604800 NOTICE: VideoPlayer: finished waiting
15:24:55.783 T:1958604800 NOTICE: VideoPlayer: Opening: http://a.files.bbci.co.uk/media/live/man...music.m3u8
15:24:55.806 T:1442051056 NOTICE: Creating InputStream
15:24:55.876 T:1442051056 ERROR: AddOnLog: InputStream Adaptive: Could not open / parse mpdURL (http://a.files.bbci.co.uk/media/live/man...music.m3u8)
15:24:55.876 T:1442051056 ERROR: CVideoPlayer::OpenInputStream - error opening [http://a.files.bbci.co.uk/media/live/man...music.m3u8]
15:24:55.877 T:1442051056 NOTICE: CVideoPlayer::OnExit()
15:24:55.877 T:1958604800 ERROR: Playlist Player: skipping unplayable item: 9, path [plugin://plugin.video.iplayerwww/?url=bbc_6music&mode=213&name=BBC+Radio+6+Music&iconimage=%2Fhome%2Fosmc%2F.kodi%2Faddons%2Fplugin.video.iplayerwww%2Fmedia%2Fbbc_6music.png&description=&subtitles_url=&logged_in=False]
15:24:55.901 T:1465037808 WARNING: Attempt to use invalid handle 8
15:24:56.100 T:1456649200 WARNING: Previous line repeats 1 times.
15:24:56.100 T:1456649200 WARNING: Attempt to use invalid handle 10
15:24:56.283 T:1481815024 WARNING: Previous line repeats 1 times.
15:24:56.283 T:1481815024 WARNING: Attempt to use invalid handle 9
15:24:56.383 T:1456649200 WARNING: Attempt to use invalid handle 10
15:24:56.483 T:1481815024 WARNING: Attempt to use invalid handle 9
15:24:56.533 T:1456649200 WARNING: Attempt to use invalid handle 10
15:24:56.655 T:1481815024 WARNING: Attempt to use invalid handle 9
15:24:56.661 T:1456649200 WARNING: Attempt to use invalid handle 10
15:24:56.796 T:1481815024 WARNING: Previous line repeats 1 times.
15:24:56.796 T:1481815024 WARNING: Attempt to use invalid handle 9
15:24:56.998 T:1456649200 WARNING: Previous line repeats 1 times.
15:24:56.998 T:1456649200 WARNING: Attempt to use invalid handle 10
15:25:04.709 T:1958604800 WARNING: Previous line repeats 1 times.
15:25:04.709 T:1958604800 NOTICE: NFS is idle. Closing the remaining connections.
--- after selecting from Chorus:
15:34:30.406 T:1466528752 WARNING: Attempt to use invalid handle 10
15:37:37.260 T:1958821888 WARNING: Previous line repeats 3 times.
15:37:37.260 T:1958821888 NOTICE: CVideoPlayer::CloseFile()
15:37:37.260 T:1958821888 NOTICE: VideoPlayer: waiting for threads to exit
15:37:37.260 T:1958821888 NOTICE: VideoPlayer: finished waiting
15:37:37.261 T:1958821888 NOTICE: VideoPlayer: Opening: http://a.files.bbci.co.uk/media/live/man...o_two.m3u8
15:37:37.285 T:1500083184 NOTICE: Creating InputStream
15:37:37.640 T:1500083184 NOTICE: Creating Demuxer
15:37:37.886 T:1474917360 WARNING: Attempt to use invalid handle 13
15:37:38.144 T:1500083184 WARNING: Previous line repeats 2 times.
15:37:38.144 T:1500083184 NOTICE: Opening stream: 0 source: 256
15:37:38.144 T:1500083184 NOTICE: Finding audio codec for: 86018
15:37:38.147 T:1500083184 NOTICE: Creating audio thread
15:37:38.148 T:1466528752 NOTICE: running thread: CVideoPlayerAudio:Tonguerocess()
15:37:38.162 T:1466528752 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
15:37:38.201 T:1500083184 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
15:37:38.449 T:1474917360 WARNING: Attempt to use invalid handle 13
15:37:48.091 T:1958821888 WARNING: Previous line repeats 4 times.
15:37:48.091 T:1958821888 NOTICE: NFS is idle. Closing the remaining connections.
