Full Version: "Tvheadend route latencies" add-on
Good day everyone,
I would like to introduce my add-on. If you watch TV streamed from Tvheadend and you have problems with buffering etc. this add-on will show you which part of network causes the problem if any. Buffering can also be the result of a weak signal in antenna or hardware problems during decoding video stream. It is often difficult to say what is the reason - this add-on can tell you if there is a problem with network. For example on a picture below you can see that all pings are low so there is no problem with network. But if ping in some step will be greater than 60-100 ms you can say that this is the problem.
The code is on GitHub: github.com/iwis/script.service.tvheadend-route-latencies
Comments/feedback/bug reports are welcome!
