Full Version: Squeezebox for Kodi
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
I just tried to run squeezelite manually. It starts and the player is visible for LMS. When i hit play, play is active for 2-4 seconds and stops. But during this "play time" there is no sound on my kodi squeezelite client. So it is the same problem as with the addon.
Ok so then there is an issue with your system aside from this add-on. it stands to reason that if you solve the issue with your system the add-on will work.
Sent from my XT1254
question, does the other addon xsqueeze run fine?
Sent from my XT1254
[quote='skarragallagher' pid='2594840' dateline='1496178974']
i am not sure anymore. "squeezebox for kodi" worked once and then after a reboot (i changed nothing) it didn't work anymore. I'm not sure if it was the same for xSqueeze. Have to check that later. Did a new clean install of libreelec and osmc. On OSMC i installed squeezelite via ssh, run it and it works. But with dropouts and for a maximum time of 3 minutes. Then i have to hit play again. With Libreelec (again after a clean install) same problem as before. No playback. Isn't it maybe a output or ALSA problem? what settings can be done besides "dtparam audio=on" in the config.txt and the "-o" output argument for default alsa card. And what can be the reason that the playback with osmc is also not working fine. I already tried the argument "-a 80" and "-a160" but it didnt help.
Tried it again on LibreElec with xSqueeze and it is working fine. No chance with manual SSH start of squeezelite and via the "Sqeezebox for Kodi" Addon. Seems like just bossanova808 can help because he knows the magic that is happening behind xSsqueeze ;-). Otherwise I have to switch to OSMC :-(
I just did another separate pi3 install, with libreelec and it of course works just fine...
(2017-06-01, 18:35)luigi2000 Wrote: [ -> ]Tried it again on LibreElec with xSqueeze and it is working fine. No chance with manual SSH start of squeezelite and via the "Sqeezebox for Kodi" Addon. Seems like just bossanova808 can help because he knows the magic that is happening behind xSsqueeze ;-). Otherwise I have to switch to OSMC :-(
Please check in your server settings that you do not have authentication required for the web interface.
It's still on my todo list to support that...
BTW: My Spotify addon for Kodi had a major upgrade and is now also interacting with squeezebox so you can use the Spotify addon on Kodi and control your squeezebox player :-)
(2017-06-02, 01:55)marcelveldt Wrote: [ -> ]Please check in your server settings that you do not have authentication required for the web interface.
Funny you are mentioning this right now, since I've been looking for that info yesterday and was just about to post a question. I'm very much looking forward to trying this out as soon as I can connect to my password protected server.
Thanks for your work!
@marcelveldt: I have no authentication set for my LMS and your Addon is working with OSMC so it must be something with Libreelec. Its just weird that xSqueeze is working on LibreElec.
@skarragallagher: can you tell me the configuration steps from installing libreelec to your working squeezebox for kodi addon? :-) Maybe its something really simple I forgot. If you have the same hard and software it must work when I do the same configuration steps. Are you also using HDMI as output?
Yeah both of mine weren't fresh installs but migration from openelec. Basically I upgraded to libreelec, modified the config file as mentioned previously in this thread, installed multimedia tools, add then installed this add-on.
Yes I use HDMI output as well.
@Marcel
Volume control on both windows and the pi3 needs some work I think. I can't seem to effectively control the player volume. Is there any way we can tie this to Kodi main volume
Thanks for this great plugin, which I am running on LibreELEC on an intel NUC. The NUC is connected through HDMI to my Denon receiver.
Unfortunately, I am not able to play content through the plugin. When playing a local song, nothing happens - no sound an no action on the GUI. And when playing a song from Spotify, I can see the song title in the upper part of Kodi. So I assume that it starts playing but I don't hear anything.
I can see the kodi squeezelite instance on my SB Server, and the connection to the server is established correctly.
I tried to use different output settings - without success.
Below's an excerpt from my kodi.log. From what I see, the squeezelite binary chooses the wrong audio device. Where do I change that?
Thx, G.
17:30:09.847 T:140653188712192  NOTICE: plugin.audio.squeezebox --> discovery: [{'from': ('192.168.0.19', 3483), 'host': '192.168.0.19', 'data': 'EJSON\x049000', 'port': 9000}]
17:30:09.848 T:140653188712192  NOTICE: plugin.audio.squeezebox --> LMS server discovered - host: 192.168.0.19 - port: 9000
17:30:12.029 T:140653188712192  NOTICE: plugin.audio.squeezebox --> Starting Squeezelite binary - Using audio device: default:CARD=PCH
17:30:12.058 T:140653188712192  NOTICE: plugin.audio.squeezebox --> Start Monitoring events for playerid f4:4d:30:66:a6:dc
17:30:33.786 T:140653938899072   ERROR: Control 55 in window 10502 has been asked to focus, but it can't
17:30:42.876 T:140652162680576   ERROR: /usr/lib/python2.7/urllib.py:1299: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
17:30:42.881 T:140652162680576 WARNING: plugin.audio.squeezebox --> Exception in plugin_content ! --> u'\xf6'
17:30:46.435 T:140652162680576 WARNING: plugin.audio.squeezebox --> Exception in plugin_content ! --> 'titles_loop'
17:30:46.707 T:140652461422336   ERROR: PVR - ConnectionStateChange - invalid handler data
17:30:47.591 T:140653160707840  NOTICE: Start - EPG thread started
17:30:48.501 T:140651136354048   ERROR: /usr/lib/python2.7/urllib.py:1299: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
17:30:48.502 T:140651136354048 WARNING: plugin.audio.squeezebox --> Exception in plugin_content ! --> u'\xf6'
17:30:57.310 T:140653938899072   ERROR: Control 55 in window 10502 has been asked to focus, but it can't
17:30:59.311 T:140651136354048   ERROR: /usr/lib/python2.7/urllib.py:1299: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
17:30:59.312 T:140651136354048 WARNING: plugin.audio.squeezebox --> Exception in plugin_content ! --> u'\xf6'
17:31:00.736 T:140651136354048 WARNING: plugin.audio.squeezebox --> Exception in plugin_content ! --> 'titles_loop'
17:31:02.342 T:140651136354048   ERROR: /usr/lib/python2.7/urllib.py:1299: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
17:31:02.349 T:140651136354048 WARNING: plugin.audio.squeezebox --> Exception in plugin_content ! --> u'\xf6'
17:31:37.123 T:140653938899072   ERROR: Control 55 in window 10502 has been asked to focus, but it can't
17:31:40.536 T:140651136354048   ERROR: /usr/lib/python2.7/urllib.py:1299: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
17:31:40.538 T:140651136354048 WARNING: plugin.audio.squeezebox --> Exception in plugin_content ! --> u'\xf6'
17:31:48.933 T:140651136354048   ERROR: /usr/lib/python2.7/urllib.py:1299: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
17:31:48.935 T:140651136354048 WARNING: plugin.audio.squeezebox --> Exception in plugin_content ! --> u'\xf6'
17:32:00.473 T:140653938899072  NOTICE: NFS is idle. Closing the remaining connections.
17:32:02.599 T:140651136354048   ERROR: /usr/lib/python2.7/urllib.py:1299: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
Great work!
Just set it up on my Windows 10 HTPC, works fine.
Can't wait to role this out to our Libreelec Weteks at home.
(2017-06-02, 21:57)skarragallagher Wrote: [ -> ]Volume control on both windows and the pi3 needs some work I think. I can't seem to effectively control the player volume. Is there any way we can tie this to Kodi main volume
I did not implement volume control at all. I will take a look if I can control the Kodi volume when I'm working on this add-on again later this week.
(2017-07-23, 18:05)GoldenEye Wrote: [ -> ]Below's an excerpt from my kodi.log. From what I see, the squeezelite binary chooses the wrong audio device. Where do I change that?
You can change the audio device in the add-on settings
So, it's been a while but I now ran some tests to set this up for my Wetek Play 2.
But it's not going so well, even with or without auto detecting of the LMS, the plugin initially finds the LMS but then gets in some trouble saying
Exception in lmsserver ! --> Server is offline or connection error...
I've had the squeezebox plugin installed and afterwords I installed the Multimedia Tools Addon, but thats not the problem?
The test setup of the LMS runs in a VM on Hyper-V with LUbuntu, works so far with a squeezelite player on my Windows notebook and can be controlled by the iOS Squeezebox App.
LMS version is the latest nightly from that link:
http://downloads.slimdevices.com/nightly...hp?ver=7.9
Can't figure out how to put this into a spoiler, so here the snippets from the kodi.log
With given IP of the LMS or auto detect, puts the same lines in the log:
03:11:28.253 T:548445814784  NOTICE: -----------------------------------------------------------------------
03:11:28.253 T:548445814784  NOTICE: Starting Kodi (17.3 Git:147cec4). Platform: Linux ARM 64-bit
03:11:28.253 T:548445814784  NOTICE: Using Release Kodi x64 build
03:11:28.253 T:548445814784  NOTICE: Kodi compiled May 25 2017 by GCC 6.2.0 for Linux ARM 64-bit version 3.14.29 (200221)
03:11:28.253 T:548445814784  NOTICE: Running on LibreELEC (official) - Version: 8.0.2, kernel: Linux ARM 64-bit version 3.14.29
03:11:28.256 T:548445814784  NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
03:11:28.256 T:548445814784  NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
03:11:28.256 T:548445814784  NOTICE: ARM Features: Neon disabled
03:11:28.256 T:548445814784  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
03:11:28.256 T:548445814784  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
03:11:28.256 T:548445814784  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
03:11:28.256 T:548445814784  NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
03:11:28.256 T:548445814784  NOTICE: special://envhome/ is mapped to: /storage
03:11:28.256 T:548445814784  NOTICE: special://home/ is mapped to: /storage/.kodi
03:11:28.256 T:548445814784  NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
03:11:28.256 T:548445814784  NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
03:11:28.256 T:548445814784  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
03:11:28.256 T:548445814784  NOTICE: Local hostname: JulianKodi
03:11:28.256 T:548445814784  NOTICE: Log File is located: /storage/.kodi/temp//kodi.log
03:11:28.256 T:548445814784  NOTICE: -----------------------------------------------------------------------
03:11:28.307 T:548445814784   ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
03:11:28.313 T:548445814784  NOTICE: load settings...
03:11:28.313 T:548445814784  NOTICE: AML device detected
03:11:28.408 T:548445814784  NOTICE: Found 2 Lists of Devices
03:11:28.408 T:548445814784  NOTICE: Enumerated ALSA devices:
03:11:28.408 T:548445814784  NOTICE:     Device 1
03:11:28.408 T:548445814784  NOTICE:         m_deviceName      : default
03:11:28.408 T:548445814784  NOTICE:         m_displayName     : Default (AML-M8AUDIO Analog)
03:11:28.408 T:548445814784  NOTICE:         m_displayNameExtra:
03:11:28.408 T:548445814784  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
03:11:28.408 T:548445814784  NOTICE:         m_channels        : FL,FR,UNKNOWN1,LFE,BL,BR,FC,BC,BLOC,BROC
03:11:28.408 T:548445814784  NOTICE:         m_sampleRates     : 32000,44100,48000,88200,96000,176400,192000
03:11:28.408 T:548445814784  NOTICE:         m_dataFormats     : AE_FMT_S32NE
03:11:28.408 T:548445814784  NOTICE:         m_streamTypes     : No passthrough capabilities
03:11:28.408 T:548445814784  NOTICE:     Device 2
03:11:28.408 T:548445814784  NOTICE:         m_deviceName      : hdmi:CARD=AMLM8AUDIO,DEV=0
03:11:28.408 T:548445814784  NOTICE:         m_displayName     : AML-M8AUDIO
03:11:28.408 T:548445814784  NOTICE:         m_displayNameExtra: HDMI
03:11:28.408 T:548445814784  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
03:11:28.408 T:548445814784  NOTICE:         m_channels        : FL,FR,BL,BR,FC,LFE,SL,SR
03:11:28.408 T:548445814784  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
03:11:28.408 T:548445814784  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
03:11:28.408 T:548445814784  NOTICE: Enumerated PULSE devices:
03:11:28.408 T:548445814784  NOTICE:         m_deviceName      : Default
03:11:28.408 T:548445814784  NOTICE:         m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
03:11:28.408 T:548445814784  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
03:11:28.408 T:548445814784  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
03:01:38.352 T:546920460512  NOTICE: plugin.audio.squeezebox --> started webproxy at port 51100
03:01:38.373 T:545200214240  NOTICE: plugin.audio.squeezebox --> Waiting for mac address...
03:01:39.375 T:545200214240  NOTICE: plugin.audio.squeezebox --> Detected Mac-Address: ac:83:f3:04:25:68
03:01:43.788 T:545766224096  NOTICE: Start - EPG thread started
03:01:44.884 T:545200214240  NOTICE: plugin.audio.squeezebox --> discovery: [{'from': ('192.168.2.222', 3483), 'host': '192.168.2.222', 'data': 'EJSON\x049000', 'port': 9000}]
03:01:44.884 T:545200214240  NOTICE: plugin.audio.squeezebox --> LMS server discovered - host: 192.168.2.222 - port: 9000
03:01:47.132 T:545200214240  NOTICE: plugin.audio.squeezebox --> Starting Squeezelite binary - Using audio device: default:CARD=AMLM8AUDIO
03:01:47.173 T:545200214240  NOTICE: plugin.audio.squeezebox --> Start Monitoring events for playerid ac:83:f3:04:25:68
03:01:47.235 T:545200214240 WARNING: plugin.audio.squeezebox --> Exception in lmsserver ! --> Server is offline or connection error...
