2017-05-08, 01:29
I haven't been able to find anyone else who is having quite the same issues as I am. When I install and launch Kodi 17.1 when I'm in the app it's causing the screen to continuously flash on and off every few seconds. The screen will go black for a couple seconds, then it will come back on for a few seconds, then off again, then on again and so on. However, I was able to download and install Kodi 17 Beta 2 with no issues. It runs just fine.
I've tried resetting my Firestick to factory/default settings, restarting it, I've un-installed and re-installed Kodi several times using the ES Explorer and Dowloader apps and it still does the same thing. Can someone please help or give some advice? Thank you!
