2017-05-09, 07:54
2017-05-09, 08:17
Set the timezone in Kodi settings.
2017-05-09, 11:19
Thank nickr,
The timezone however only has locations, closest to UTC is UK/London, However Londen is using DaylightSavings, and is currently UTC+1.
I have not found any static timezones like GMT, UTC, BST in the list. Or am i overlooking something obvious here ?
2017-05-09, 20:57
I don't know anything about Libreelec.
But on every Linux I know, the available timezones are stored in /usr/share/zoneinfo. And there exits a file UTC. According to the Arch-Wiki you should link the zone file to /etc/localtime.
The same you can do with timedatectl set-timezone UTC.
2017-05-09, 21:58
LibreELEC is a bit different to other distros as /etc is read only.
TIMEZONE is kept in /storage/.cache/timezone
2017-05-10, 11:46
last time I looked, timedatectl wasn't available on LE
2017-06-16, 15:47
(2017-05-09, 21:58)nickr Wrote: [ -> ]LibreELEC is a bit different to other distros as /etc is read only.
Thanks nickr, how can i use that info to do what i wanted ? Make kodi use the UTC time ?
2017-06-16, 18:27
ln -s /usr/share/zoneinfo/UTC /storage/.cache/timezone
