Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
So, I've found some project to be able to "activate" and put on standby the CEC but it looks like it no longer works with Kodi 17. Any way to somehow integrate this to this current project? Here's the link og the github project:
https://github.com/joshjowen/script.json-cec
thanks again for the hard work of you 2, much appreciated.
(2017-07-31, 02:00)stoned99 Wrote: [ -> ]So, I've found some project to be able to "activate" and put on standby the CEC but it looks like it no longer works with Kodi 17. Any way to somehow integrate this to this current project? Here's the link og the github project: https://github.com/joshjowen/script.json-cec
That's a great find, thanks!
I've added this and it worked for me (see the github project for details),
It looks like it only works on Kodi 17 and above.
(2017-08-02, 07:42)omertu Wrote: [ -> ] (2017-07-31, 02:00)stoned99 Wrote: [ -> ]So, I've found some project to be able to "activate" and put on standby the CEC but it looks like it no longer works with Kodi 17. Any way to somehow integrate this to this current project? Here's the link og the github project: https://github.com/joshjowen/script.json-cec
Working great! I also added the option to turn off TV (and audio receiver) in my code. Just not sure how to add in your code. Basically added this code:
// CEC standby
app.get("/standbytv", function (request, response) {
validateRequest(request, response, kodiStandbyTv)
var kodiStandbyTv = function(request, response) {
console.log("Standby TV request received");
var params = {
addonid: "script.json-cec",
params: {
command: "standby"
kodi.Addons.ExecuteAddon(params);
Hi Guys !
Just a question : this method can work with other language ?
I'm french, and i bought 2 days ago the french version of Google Home.
Thx for your help
(2017-08-09, 18:44)ArmoiraglatZ Wrote: [ -> ]Hi Guys !
Thx for your help
Yes it works in French but it's quite new. Recently, IFTTT added a language selector, just select French from the drop down. Make sure to change all the lines for French stuff
(Kodi allume la télé, Kodi, éteint la télé, etc)
I was happy when i see your project but port forwarding without https or firewall... (I am on LibreElec)
I 'm note sure if it is a good idea
Also i have a dynamic IP :/
Is there an other possibility?
It's HTTPS.
Regarding dynamic IP, just use any dyndns service like no-ip and use that instead of your IP in the script. That's what I did it and it works fine.
(2017-08-09, 22:24)stoned99 Wrote: [ -> ]It's HTTPS.
Ok for the ddns but https on KODI? 8080?
you access your Glitch URL with https.
(2017-08-09, 22:30)stoned99 Wrote: [ -> ]you access your Glitch URL with https.
Ok, but kodi is open to internet on http :/
I am disappointed by Alexa/Google home and their limitations (nothing works in LAN)
(2017-08-09, 22:38)Xianghua Wrote: [ -> ] (2017-08-09, 22:30)stoned99 Wrote: [ -> ]you access your Glitch URL with https.
Lol their both cloud based APIs how could it run on LAN?
Sent from my SM-G935T
I don't know :p
I have the same problem with my LMS server (Squeezebox)
But great works omertu !
(2017-08-09, 19:04)stoned99 Wrote: [ -> ]Yes it works in French but it's quite new. Recently, IFTTT added a language selector, just select French from the drop down. Make sure to change all the lines for French stuff (Kodi allume la télé, Kodi, éteint la télé, etc)
Hi Guys !
FYI it works perfectly in french with IFTTT !
Thanks for tour work and have fun with GH !
"Ok Google ! Who's my father ?"
"I think you can found the answer in Kodi with Star Wars. Playing Star Wars in TV"
**Off Topic** I really want one of these GHome things now. Just worried about having one in a "multi-user" home. For instance, I have my NEST thermostats locked to no warmer than 70 degrees in the winter month because the other occupants of the home (the ones that DONT pay the heating bill) believe that magical heat fairies just show up and warm the house up. So I'm worried that they would be able to "override" the max heat setting on the thermostat - among other such things...
Step B4, I can't find a private option to set...
Anyone know where this is meant to be, the advanced options doesn't have that option in Glitch.
