Full Version: problems wfile:///usr/share/ubuntu-artwork/home/index.html with apt-get procedure. t
Hello, just installed ubuntu 7.10.
The problem is when using apt-get. I get to 93%. FOllowed the wiki.
It displays the following:
Media change: please insert the disc labeled
'Ubuntu 7.10 _Gutsy Gibbon_ - Release i386 (20071016)'
in the drive '/cdrom/' and press enter
I got the cd inserted, press enter. Then the same text appears again. Then I just goes on and on and on and on with this, still stuck on 93%. No matter how many times i press enter. Also tried with 2different cds.
Any suggestions?
BR
also when i try to compile I obvious get error. SE following code below.
Local source revision : 11773
Repository revision : 11773
Your source is up to date.
Configuring build.
checking for gawk... no
checking for mawk... mawk
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl.exe... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking for C++ compiler default output file name...
configure: error: C++ compiler cannot create executables
See `config.log' for more details.
Go into the repository sources and tell it to NOT use the CD as a resource. It will stop asking for the CD and get it off the 'net. You may have to cancel and re-get the code but it will get you out of this loop.
Please take you ubuntu questions to the ubuntu forums. We are not responsible for supporting their distribution.
ty BLKMGK. successfully installed ubuntu and compiled with script. Followed the wiki and it works like a charm. Even a noobie like me could install it.
althekiller.
Your'e just mean, come over to my house and I will give you a cookie and make you happy!
BR
I'm not mean, you're abusing our forums.
