Hi
Im attempting to use some JSON commands in a kodi app im playing with but most examples use the requests library. But if i try to import the library ("import requests") it breaks my code.. So i think ive just missed something important somewhere could someone point me in the right direction for getting this working?
Thanks for the responses!
(2017-05-13, 04:24)MetalChris Wrote: [ -> ]Is the requests module installed on your system? If not: script.module.requests-2.12.4.zip
See i thought it should be installed as it is listed here "http://kodi.wiki/view/Category:Add-on_libraries/modules" how do i check if its installed?
(2017-05-13, 04:24)MetalChris Wrote: [ -> ]If not: script.module.requests-2.12.4.zip
And if i find its not installed how do i go about installing this? Sorry im real noob with this kodi stuff
(2017-05-13, 05:07)Lunatixz Wrote: [ -> ]If you are trying to access a json response from a local Kodi instance use Kodi's API, request modules only needed to access LAN response.
https://codedocs.xyz/xbmc/xbmc/group__py...9ed84ed846
Sent from my SM-G935T (typie typie)
Yep i am trying to access LAN response, not local
Ok so after a bit more searching i found this thread:
http://forum.kodi.tv/showthread.php?tid=263922
in which sounds like someone having the same issue as me. So after following this i added into script.module.requests-2.12.4 into \Kodi\addons
added to addon.xml
<import addon="script.module.requests" version="2.12.4"/>
in addon.py
import requests
but i still get an error
am i putting the lib in the correct spot? In the kodi addon settings i've allowed from unknown sources, is there something else i should be doing?
(2017-05-13, 12:48)NeoNator Wrote: [ -> ]So after following this i added into script.module.requests-2.12.4 into \Kodi\addons
You can no longer simply drop a folder into the addons directory. You'll need to
install from zip.
That was it! thanks mate really appreciate it!!!
Excellent! Keep us posted with your progress.
