Im having the same problem as everyone else. Ive searched through previous posts and tried different build downloads and nothing fixed issue ive been searching and trying for hours. I ran a debug
https://paste.ubuntu.com/24567358/ everything is at up to date firmware Samsung galaxy s6 active running nougat. The problem started when I updated to nougat. Tia
Known. Samsung fucked up their 7.0 release, we informed them - they don't care.
Thanks for a quick reply. Is there a fix for this whatsoever? Or just wait and use Bluetooth for now?
Call Samsung and yell at them
(2017-05-13, 15:57)Jmcfarlin Wrote: [ -> ]Thanks for a quick reply. Is there a fix for this whatsoever? Or just wait and use Bluetooth for now?
I can create a PITA build that will remove all but the lowest quality audio transmission format ...
Fritsch it works flawlessly thanks so much. Ive been searching tirelessly for 3 days looking for a solution before giving up.
I was going to suggest turning OFF the Kodi Krypton Audio - "Send Low volume noise" generation option - we have seen problems with various LibreELEC devices with headphone outputs with that option left enabled by default.
(2017-05-14, 07:48)wrxtasy Wrote: [ -> ]I was going to suggest turning OFF the Kodi Krypton Audio - "Send Low volume noise" generation option - we have seen problems with various LibreELEC devices with headphone outputs with that option left enabled by default.
Won't help him. And btw. the issues you most ikely have with AML on LE right? The driver hacks are not meant to keep analog working properly.
