Full Version: screen flickers when loading channel from epg
I'm having and issue with kodi 17 across multiple skins. If I currently have a channel playing, open the epg and change the channel the active playing channel and the epg flicker back and forth between each other until the new channel loads.
If a channel isn't already playing when I choose a channel from the epg then the channel will load as expected with a 'loading' wheel.
Below is a log from when I perform the described actions above (changing channels from the epg while a channel is currently playing and waiting for the new channel to load).
17:46:04.382 T:140483777138176  NOTICE: CVideoPlayer::CloseFile()
17:46:04.382 T:140483777138176  NOTICE: VideoPlayer: waiting for threads to exit
17:46:04.392 T:140479561914112  NOTICE: CVideoPlayer::OnExit()
17:46:04.392 T:140479561914112  NOTICE: Closing stream player 1
17:46:04.392 T:140479561914112  NOTICE: Waiting for audio thread to exit
17:46:04.399 T:140481040205568  NOTICE: thread end: CVideoPlayerAudio::OnExit()
17:46:04.399 T:140479561914112  NOTICE: Closing audio device
17:46:04.434 T:140479561914112  NOTICE: Deleting audio codec
17:46:04.434 T:140479561914112  NOTICE: Closing stream player 2
17:46:04.434 T:140479561914112  NOTICE: waiting for video thread to exit
17:46:04.476 T:140481585469184  NOTICE: thread end: video_thread
17:46:04.477 T:140479561914112  NOTICE: deleting video codec
17:46:04.477 T:140479561914112  NOTICE: CVDPAU::Release pre-cleanup
17:46:04.477 T:140481560291072  NOTICE: CMixer::OnExit: Output Thread terminated
17:46:04.477 T:140479561914112  NOTICE: Closing stream player 4
17:46:04.478 T:140479561914112  NOTICE: waiting for teletext data thread to exit
17:46:04.478 T:140482273343232   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
17:46:04.478 T:140482273343232  NOTICE: thread end: data_thread
17:46:04.543 T:140483777138176  NOTICE: VideoPlayer: finished waiting
17:46:04.543 T:140483777138176  NOTICE:  (VDPAU) Close
17:46:04.543 T:140483777138176  NOTICE:  (VDPAU) FiniVDPAUOutput
17:46:04.543 T:140482122340096  NOTICE: VDPAU::COutput: vdpau gl interop finished
17:46:04.545 T:140482122340096  NOTICE: COutput::OnExit: Output Thread terminated
17:46:04.545 T:140483777138176  NOTICE: VDPAU::Close - closing decoder context
17:46:04.546 T:140483777138176  NOTICE: VideoPlayer: Opening: pvr://channels/tv/All channels/pvr.iptvsimple_1381159378.pvr
17:46:04.546 T:140482122340096  NOTICE: Creating InputStream
17:46:07.620 T:140482122340096  NOTICE: Creating Demuxer
17:46:07.906 T:140482122340096  NOTICE: Opening stream: 0 source: 256
17:46:07.906 T:140482122340096  NOTICE: Creating video codec with codec id: 28
17:46:07.906 T:140482122340096  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:46:07.907 T:140482122340096  NOTICE: Creating video thread
17:46:07.907 T:140482122340096  NOTICE: Opening stream: 1 source: 256
17:46:07.907 T:140482122340096  NOTICE: Finding audio codec for: 86018
17:46:07.907 T:140479503152896  NOTICE: running thread: video_thread
17:46:07.908 T:140482122340096  NOTICE: Creating audio thread
17:46:07.908 T:140482122340096  NOTICE: Opening stream: 2 source: 256
17:46:07.908 T:140482122340096  NOTICE: waiting for teletext data thread to exit
17:46:07.908 T:140482273343232  NOTICE: running thread: CVideoPlayerAudio::Process()
17:46:07.909 T:140482122340096  NOTICE: Creating teletext data thread
17:46:07.910 T:140483112163072  NOTICE: running thread: CDVDTeletextData
17:46:07.927 T:140482122340096  NOTICE: Opening stream: 0 source: 256
17:46:07.927 T:140482122340096  NOTICE: Creating video codec with codec id: 28
17:46:07.927 T:140482122340096  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
17:46:07.927 T:140482122340096  NOTICE: Opening stream: 1 source: 256
17:46:07.928 T:140482122340096  NOTICE: Opening stream: 2 source: 256
17:46:07.928 T:140479503152896  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating VDPAU(1920x1080)
17:46:07.928 T:140482273343232  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
17:46:07.928 T:140479503152896  NOTICE: VDPAU::CreateContext - creating decoder context
17:46:07.930 T:140479503152896  NOTICE: vdp_device = 0x00000001 vdp_st = 0x00000000
17:46:07.930 T:140479503152896  NOTICE: VDPAU Decoder capabilities:
17:46:07.930 T:140479503152896  NOTICE: name          level macbs width height
17:46:07.930 T:140479503152896  NOTICE: ------------------------------------
17:46:07.930 T:140479503152896  NOTICE: MPEG2_SIMPLE      3  9216  2048  1152
17:46:07.930 T:140479503152896  NOTICE: MPEG2_MAIN        3  9216  2048  1152
17:46:07.930 T:140479503152896  NOTICE: H264_BASELINE    41  9216  2048  1152
17:46:07.930 T:140479503152896  NOTICE: H264_MAIN        41  9216  2048  1152
17:46:07.930 T:140479503152896  NOTICE: H264_HIGH        41  9216  2048  1152
17:46:07.930 T:140479503152896  NOTICE: VC1_SIMPLE        1  9216  2048  1152
17:46:07.930 T:140479503152896  NOTICE: VC1_MAIN          2  9216  2048  1152
17:46:07.930 T:140479503152896  NOTICE: VC1_ADVANCED      4  9216  2048  1152
17:46:07.930 T:140479503152896  NOTICE: MPEG4_PART2_ASP   5  9216  2048  1152
17:46:07.930 T:140479503152896  NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_NOISE_REDUCTION
17:46:07.930 T:140479503152896  NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_SHARPNESS
17:46:07.930 T:140479503152896  NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_DEINTERLACE_TEMPORAL
17:46:08.183 T:140479503152896  NOTICE:  (VDPAU) screenWidth:1920 vidWidth:1920 surfaceWidth:1920
17:46:08.183 T:140479503152896  NOTICE:  (VDPAU) screenHeight:1080 vidHeight:1080 surfaceHeight:1088
17:46:08.185 T:140481040205568  NOTICE: COutput::OnStartup: Output Thread created
17:46:08.436 T:140481040205568  NOTICE: VDPAU::COutput::CreateGlxContext - created context
17:46:08.436 T:140481040205568  NOTICE: VDPAU::COutput: vdpau gl interop initialized
17:46:08.436 T:140482223085312  NOTICE: CMixer::OnStartup: Output Thread created
17:46:08.436 T:140482223085312  NOTICE:  (VDPAU) Creating the video mixer
17:46:08.437 T:140481040205568  NOTICE: VDPAU::COutput::InitBufferPool - Output Surface created
17:46:08.446 T:140481040205568  NOTICE: Previous line repeats 6 times.
17:46:08.446 T:140481040205568  NOTICE: VDPAU::COutput registered output surfaces
17:46:08.553 T:140483777138176  NOTICE: Previous line repeats 6 times.
17:46:08.553 T:140483777138176  NOTICE: GL: Using VDPAU render method
17:46:08.553 T:140483777138176  NOTICE: GL: NPOT texture support detected
17:46:08.553 T:140483777138176  NOTICE: GL: Using GL_ARB_pixel_buffer_object
17:46:08.553 T:140483777138176  NOTICE: Using GL_TEXTURE_2D
17:46:09.068 T:140479503152896 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
17:46:09.518 T:140479503152896  NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 40000
This is not a Debug Log
Sorry about that. Here ya go.
https://pastebin.com/UZw9dm6D
Please use PasteBin.com or a similar site to host logs. Do not post them here, as it boasts the forum database unnecessarily.
If you could transfer the log there and remove it above please.
Done
ttt
The log isn't complete.
