2008-02-23, 13:07
2008-02-23, 14:16
use dvdplayer core if the media is supportedf by dvd player and this is on the xbox.
xbmc.Player(xbmc.PLAYER_CORE_DVDPLAYER)
if this is a local file and mplayer you can use nocache=1 in a .conf file named like this.
movie name.mov
movie name.mov.conf
movie name.mov
movie name.mov.conf
2008-02-23, 14:38
I've forgot to mention that i am using the linux port, so there's no mplayer i could use.
I am trying to open a HTTP Stream from my local VDR, which is actually on the same box but it only supports local connections via a pipe which the dvdplayer cant handle.
The main problem is the libcurl debug connection (easy_aquire) which stops responding after running into a timeout after 5000 milliseconds. Then the "real?" DVDPlayer starts to open the given location (CPlayerCoreFactor::GetPlayers(http://192.168.0.1:37890)) and starts caching, which isnt needed for replaying tv live streams ..
Any other hints or suggestions ?
2008-02-24, 11:18
Nuka1195 Wrote:use dvdplayer core if the media is supportedf by dvd player and this is on the xbox.
movie name.mov
movie name.mov.conf
Does this .conf file work also with .strm files? aqnd Can i tell in .conf what player to use.
I'm streaming liveTV channels from DreamBox and DVD player is needed to get subs to work.
2008-02-24, 13:35
dvdplayer does not support .conf files. I do not know how to turn caching off for dvdplayer on linux.
I thought there was talk about distinguishing between a local address and an internet, but elupus is best to ask on that.
